chevscalade209 Posted November 14, 2009 Report Share Posted November 14, 2009 which is better for the money which is most affective Quote 2 jl audio 12w3's sealed soon to be 4 level 3 15's blow through all dc audio Link to comment Share on other sites More sharing options...
jrplayer36 Posted November 14, 2009 Report Share Posted November 14, 2009 I just did my truck with second skin well worth it. Quote jrplayer36 Link to comment Share on other sites More sharing options...
Bumpindemlowzz Posted November 14, 2009 Report Share Posted November 14, 2009 The secondskin spl tiles look good and i only heard good stuff about them. Im going to get some for my doors sooner or later. Quote 2010 Silverado 18" DC XL 18 DC 2k XS Power Batts Link to comment Share on other sites More sharing options...
Mendozauly Posted November 14, 2009 Report Share Posted November 14, 2009 They all do the same thing. As long as it's done right. Cost? I did my Expedition top and bottom to much $ for Dynomat. I will shop next time. Heat gun and a Roller and lot of time. Took me about two weeks for my truck. Taking all the car apart and applying, re-installing interior. Quote Alpine D900 head unit 7" flip out t.v Kicker 6 1/2 components (front,rear)KS 6502 MB quart 3 1/2" in front A/C vent's (center channel) DC Audio LVL 5 18" (pair) Custom ported box Sundown 4500 at .5 Sundown 100.4 XS 3100 up front and a pair of XS 6500 in the rear. 1 17" Eiger Vision T.V 2 7" Eiger Vision T.V in Second row. Dynomat Top to Bottom (foam in all halo beam's) DC Eng Alt 260SP and a 400SP dual set up. big 3 Sitting on 24" If your neighbor don't complain it's not Loud! So you best go fix your shit !!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
Dr. Johnson Posted November 14, 2009 Report Share Posted November 14, 2009 They all do the same thing. As long as it's done right. Cost? I did my Expedition top and bottom to much $ for Dynomat. I will shop next time. Heat gun and a Roller and lot of time. Took me about two weeks for my truck. Taking all the car apart and applying, re-installing interior. Do you personally have experience working with all three companies? There IS a difference I have used all three and a couple others and there is a difference in what the outcome will be. You defiantly get what you pay for! I will only use Second Skin From now on! Quote Link to comment Share on other sites More sharing options...
Mendozauly Posted November 14, 2009 Report Share Posted November 14, 2009 Ok what are they? I have used Dyno and Sch. Dyno was a lot more expensive and the application was hard. Quote Alpine D900 head unit 7" flip out t.v Kicker 6 1/2 components (front,rear)KS 6502 MB quart 3 1/2" in front A/C vent's (center channel) DC Audio LVL 5 18" (pair) Custom ported box Sundown 4500 at .5 Sundown 100.4 XS 3100 up front and a pair of XS 6500 in the rear. 1 17" Eiger Vision T.V 2 7" Eiger Vision T.V in Second row. Dynomat Top to Bottom (foam in all halo beam's) DC Eng Alt 260SP and a 400SP dual set up. big 3 Sitting on 24" If your neighbor don't complain it's not Loud! So you best go fix your shit !!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
Marlo Stanfield Posted November 14, 2009 Report Share Posted November 14, 2009 I've played around with everything from SS to Dynamat to Peel and Seal... The single best product I've used is Second Skin Damp Pro. Quote 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace Link to comment Share on other sites More sharing options...
