Burned My Amp.. For No Reason?
hargibi
Hey.
So i burned my amp yesterday. The only thing i did change was that i added a 21mm2 power cable and a new ground.....
So it started up fine.. i could play some.. but then i turned it up to the usual volume i play in and then it just went quiet... The fuse under the hood had broken .. and the amp was smoking like hell..
No fuse on the amp went tho...
I had an insurence so they will fix it or get me a new for 20$ (gotta love insurence)
So. Anyone know what could have hapened?
/thanks. Joakim.
Only thing I can think is that it shorted due to your power wire grounding out somewhere. Have you checked the wire you installed?
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
What fuse rating does the amp have & what fuse was in the holder up by the battery?
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
The ground cable is good. i even have a 8mm2 cable going directly to the battery. also 1 8mm and 1 21 mm that goes to the chassi
so there should be ANY problems!
i think its 30 amps on the fuse (changed it to 50 as the store said when i wanted a new one)
And the amps are running 3*40 i think
but that is the standard fuses so there shouldnt be any problem at all.
if you have 3 40 amp fuses. then you need at least a 120 amp fuse under the hood. a 50 amp fuse wont do anything except blow and possibly mess up your amp.
18's in a wall to come....Its not all about the posts....check the member #...
  • Who's Online   1 Member, 0 Anonymous, 1764 Guests (See full list)
