hargibi Posted May 8, 2007 Report Share Posted May 8, 2007 Hey. So i burned my amp yesterday. The only thing i did change was that i added a 21mm2 power cable and a new ground..... So it started up fine.. i could play some.. but then i turned it up to the usual volume i play in and then it just went quiet... The fuse under the hood had broken .. and the amp was smoking like hell.. No fuse on the amp went tho... I had an insurence so they will fix it or get me a new for 20$ (gotta love insurence) So. Anyone know what could have hapened? /thanks. Joakim. Link to comment Share on other sites More sharing options...
roscoe1129 Posted May 8, 2007 Report Share Posted May 8, 2007 Only thing I can think is that it shorted due to your power wire grounding out somewhere. Have you checked the wire you installed? Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER Link to comment Share on other sites More sharing options...
Chris Posted May 8, 2007 Report Share Posted May 8, 2007 What fuse rating does the amp have & what fuse was in the holder up by the battery? 4 15" FI Q D2's in 12 cubes tuned to 32hz 1- T1000.1bd's 3 Maxx 29 deep cycles 4 runs of 1/0 gauge -Big 3 -Trunk sealed off from the cabin Custom 15.8 dual-volt switching MLA module All in a CAR. Link to comment Share on other sites More sharing options...
hargibi Posted May 8, 2007 Author Report Share Posted May 8, 2007 The ground cable is good. i even have a 8mm2 cable going directly to the battery. also 1 8mm and 1 21 mm that goes to the chassi so there should be ANY problems! i think its 30 amps on the fuse (changed it to 50 as the store said when i wanted a new one) And the amps are running 3*40 i think but that is the standard fuses so there shouldnt be any problem at all. Link to comment Share on other sites More sharing options...
mtxcivic07 Posted May 9, 2007 Report Share Posted May 9, 2007 The ground cable is good. i even have a 8mm2 cable going directly to the battery. also 1 8mm and 1 21 mm that goes to the chassiso there should be ANY problems! i think its 30 amps on the fuse (changed it to 50 as the store said when i wanted a new one) And the amps are running 3*40 i think but that is the standard fuses so there shouldnt be any problem at all. if you have 3 40 amp fuses. then you need at least a 120 amp fuse under the hood. a 50 amp fuse wont do anything except blow and possibly mess up your amp. 18's in a wall to come....Its not all about the posts....check the member #... Link to comment Share on other sites More sharing options...
