uhh yes it does. highlight the part of the song you want to find out what HZ its at then plot spectrum. change settings to LOG and 16384 or something and the peak should be there
that audacity plot spectrum thing can be very confusing
i was once told there was a peak at -3 hertz....
so i dont really get how to use it either
Edited by IH8PunkRok
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
get audacity
import the song
zoom in a few times using the magnifying glass with +
highlight .5-1 second of the note u want
go to analyze
plot spectrum
change 512 to 16384
change linear to log
Scroll cursor over gragh and match the peak with the cursor and there is ur peak hz and db level
A db level of 20+ is loud, i try to get mine at 23-26db... and sine waves are whatever u have
If u have a 0db sine wave its 30db on audacity(max)... if u use -3db it would be 27db on audacity
By highlighting such a little amout u get a more accurate db level than highlighting 20seconds or more since more notes occur it averages them out
You can easily see once u zoom if the data exceeds the top and bottom (clipping) and determine the severity of it, along with any other flats spots that should stand out
Edited by Decaf
perfect decaf
thank you so much for that clear explanation
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
