Posted (edited)
way to high??? are you serious? its not even to the first line...
EDIT: wow sorry i was looking at that completely backwards. it probably is too high but i have no way of tuning correctly...i dont have an o-scope and dont kno how to use a multi meter to do it
but my real question is, why did it JUST start doing it after ive had for like 2-3 months??
Edited by smitt808
Ascendant Audio Havoc 15 D1
4.5 cubes tuned LOW...28hz
Alpine MRP-M1000
Front Stage: Infinity Reference 5 1/5
Rear: Infinity Reference 6x9
Alpine CDA-117 with power pack
240a DC Power alt
Big 3 in 2ga.
97 Monte Carlo(R.I.P.)
I'm pretty sure that the 'arrow' the actual knob forms points to where its set. If so it would be at 3/4 right now.
Either that or your bass boost is all the way up which could also be an issue.
Too many projects, too little time...
ya i just went and checked that out and i edited my post but u replied too fast lol
Alpine MRP-M1000
240a DC Power alt
Big 3 in 2ga.
for tuning with a DMM I use this link http://web.archive.org/web/20080104010047/...rum/setgain.asp
you just insert the rated RMS power of your amp and the ohm load at the amp and it tells you how many AC volts you should see. hook up your probes to the speaker outputs without a sub on them, set volume (i usually tune at the highest level that I use on the HU, but some people say 3/4 volume) and play a 50-60Hz tone. Adjust the gain until you get the voltage prescribed.
As for why it's just now happening, I have no clue.
ok, and by DMM you mean Digital MultiMeter? right? or am i a supernoob? lol
Alpine MRP-M1000
240a DC Power alt
Big 3 in 2ga.
Does it cut off while you turn your volume high? Does it come off on every songs or some?
all wiring is fine
and its all songs and it doesnt even have to be up loud or anything the amp just gets hot as fuck and gets quiet
Alpine MRP-M1000
240a DC Power alt
Big 3 in 2ga.
i would turn set your gain at 1/4 max and turn the bass eq down a bit. see if that works out for you. does the amp slowelly shut down or does it just shutdown instantly?
"i'd rather die like a man than live like a coward" quoted from Tupac
