LunatikGixxer Posted November 23, 2009 Report Posted November 23, 2009 Im still deciding whether i should put the amp on the back of the box or somewhere else. On the back of the box would be the easiest place but im concerned about heat getting to it and something rattling loose inside the amp. If i do put it on the box its gunna be on 2 15s which i think might rattle it a lot... Give me some suggestions if this is a good idea or not, or where u guys perfer putting your amps at. The face of the box is double MDFed so i think it might be ok with the rattling but not sure yet (dont have it in yet). 2002 Dodge durango 4.7L Autopage 2 way remote start alarm system 2 AQ 15 Aluminum coils. 1 AQ2200D (soon to be 2). 8.5 cubes tuned to 38hz. Yellow top under hood. Kinetik 1800 in rear. Big 3. (H/O Alt Soon to come) Kicker ZX200.4 Kicker 6.5 doors (blown) RF 6.5 comp set (soon to come) 1 run of Stinger 1/0 guage (soon to be 3) All of the above is all gone Currently own a 2000 Pontiac Trans Am WS6 No audio components.
berniebp87 Posted November 23, 2009 Report Posted November 23, 2009 I had my amps on the box and had no problems with it But some amps are more fragile than others to vibrations. Proud member of SMD My build log 2 DDZ9518 2 DynaBel BF 8501 2 GZ Neo 8"s 154.5@38hz with 2 DD Z9518`s 145.5@40hz with 2 DD 1508`s My youtube vids
raytard Posted November 23, 2009 Report Posted November 23, 2009 somewhere else if you can...mounting on the box is kinda a last resort. Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
jizazz12 Posted November 23, 2009 Report Posted November 23, 2009 i have all of my amp's mounted on my box,only because i have no choice . i haven't had any problems but if you have the room it's better to mount them else where just to be on the safe side.or if your like me and have no choice due to limited space just make sure to put some rubber matting underneath the amp to absorb some of the vibration and you should be good. 2007 Chevy Impala LS 1 Crescendo 3KWP 1Crescendo C1000/4 2 DC lvl 4 15's with lvl5 dual .7 coils 1Audio Control Matrix 1 Pioneer P880PRS 1 300 amp Iraggi alt All power runs done with Knu flex 0/1 guage 1 optima yellow top under the hood 1 XS 5100 and two Deka's in the trunk 4 Crescendo MP-8 mid bass drivers 2 DB Drive p5 5 D Pro Audio tweeters
LoudBimmer Posted November 23, 2009 Report Posted November 23, 2009 can you stick it under your seat?
Bigg Boy Posted November 23, 2009 Report Posted November 23, 2009 I have my amps on my box, but box is 3" thick and I use small rubber gaskets under the feet of the amp. Dodge Magnum with custom 300c front end, laid out on air bags *4) 12" Cadence Daytona walled *1) AudioQue 20k *270a DC Power Alt (Dual coming soon)
LunatikGixxer Posted November 23, 2009 Author Report Posted November 23, 2009 alright guys i think im going to mount it under my seat. Hopefully i have enough wire to reach that far 2002 Dodge durango 4.7L Autopage 2 way remote start alarm system 2 AQ 15 Aluminum coils. 1 AQ2200D (soon to be 2). 8.5 cubes tuned to 38hz. Yellow top under hood. Kinetik 1800 in rear. Big 3. (H/O Alt Soon to come) Kicker ZX200.4 Kicker 6.5 doors (blown) RF 6.5 comp set (soon to come) 1 run of Stinger 1/0 guage (soon to be 3) All of the above is all gone Currently own a 2000 Pontiac Trans Am WS6 No audio components.
