kl0wn Posted November 24, 2009 Report Posted November 24, 2009 Okay, well I currently have my AQ1200D wired up like this. With only 1 positive and 1 negative coming out, but on the AQ1200D it has the dual positive/negative terminals on it for the speaker wire. If I ran it like this... Negative (1) on amp ---------------------- Negative terminal on sub Negative (2) on amp ---------------------- Negative terminal on sub Positive (1) on amp ----------------------- Positive terminal on sub Positive (2) on amp ----------------------- Positive terminal on sub Would the sub be seeing more power? This is first amp I have owned or wired up that has had the dual speaker wire terminals 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
etaks_crew Posted November 24, 2009 Report Posted November 24, 2009 I don't think it would. I think it has more hook ups so it's easier to run more than one sub.
Decaf Posted November 24, 2009 Report Posted November 24, 2009 it might see less resistance with the extra wire but not much... if u have the wire do it
JPagan Posted November 24, 2009 Report Posted November 24, 2009 It has 4 terminals on the amp just for ease of wiring. The 4 terminals are wired in a parallel internally.
kl0wn Posted November 24, 2009 Author Report Posted November 24, 2009 Ight y'all, thanks for the input! 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
Marlo Stanfield Posted November 24, 2009 Report Posted November 24, 2009 You'd be hard pressed to see any sort of difference in sound or output between the two. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
