c_stud Posted November 24, 2009 Report Posted November 24, 2009 i know Lanzar isn't as big/good as RF, DC, Sundown, DAT, etc. but you think that this amp does the rated wattage? SPECS 2 x 1340 Watts RMS @ 4 OHMS 2 x 2400 Watts RMS @ 2 OHMS 2 x 4100 Watts RMS @ 1 OHM 2 x 13,000 Watts Peak @ 1 OHM Mono Block Subwoofer BIG POWER Amplifier 1 Ohm Stable MOSFET Power Supply PWM(Pulse-Width-Modulated) System Glass Epoxy PCB Gold plated RCA Inputs Gold plated Line outs Custom Terminal Block for Speaker Connections Thermal,Overload Short Protection Variable Low pass Filter (35Hz~250Hz,24dB/Octave) Variable Subsonic Filter (10Hz~50Hz,24dB/Octave) Phase Control 0-180 degree Remote Bass Control Input Impedance:10K Ohms Soft Turn On/Off THD: 0.1%. S/N Ratio: 90B Input Sensitivity: 200mv~7.6V Freq. Response: 20Hz~250Hz Dimensions :12.99''W x 2.63''H x 31.49''L 1998 Nissan 200sx NOW: Dex-p98r head Planet Audio 300.4 mids and highs Planet Audio/Pioneer tweeters/crossovers Skar SK1500.1 3 SKAR Vvx15 dual 4 wired at .63
Marlo Stanfield Posted November 24, 2009 Report Posted November 24, 2009 If they are anything like the other Opti amps then it will do pretty close to rated... I know the MSRP isn't the actually selling price, but damn that is a big number. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
Boon Posted November 24, 2009 Report Posted November 24, 2009 I think the 2 x blah blah power ratings are a mistake, it's 1x. Monoblock. I think that amp has the same guts as a SoundStream XXX-6500. 10.x volts fo' life!
Marlo Stanfield Posted November 24, 2009 Report Posted November 24, 2009 I think the 2 x blah blah power ratings are a mistake, it's 1x. Monoblock. I think that amp has the same guts as a SoundStream XXX-6500. Are you sure you're not thinking of the Opti6000D?? I'm pretty sure that had the same guts to the XXX6500 but not 100% positive. Definitely would like to open this up and see what's cooking inside of it. Who knows though, I really doubt many people at all will be running this amps unless they do get a very nice price on 'em. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
sound xtreme Posted November 24, 2009 Report Posted November 24, 2009 i ran 4 of these in my no wall set up a few years ago, they do the rated power. and yes, they are the same board as the xxx6500, however, the soundstream will continue to gain with higher voltage, where the opti didnt produce any more power above 15.6V. 1997 Astro front:6 sets of T3 componets Subs: 8 level 5 18"s (building 6th order BP) Amps: 4 really big ones (totalling just shy of 50K) Batts: Alt: Ohio Generator 1996 Chevy Suburban Sub amp: A fifth really big amp Subwoofer: 2-15" DC Level 4 XL Batts: C&D high rate--(x4)
