i have a little bit of a problem .
ever since i had the 4 15s in my car , what ever woofers i put in there sounds absolutely shit .
i took the 4 15's out , dropped in 2 of those 15's and it sounded SHIT , i took those two out thinking the 5cuft box is too small and dropped in my single DD 15inch in a 5cuft box tuned to 30hz . it sounded nice and clean , but not loud at all.
so im thinking i stuffed up there , i dropped the dd into a sealed box . thinking that nothing can really be wrong with sealed box . to my surprise . its even worse!
I cant live with out the 4x15's , but theres no space in the car for them there on a daily base.
is my hearing damaged ? or am i just too used to the 4x15's?
what they hell should i do ?
go without sound for a month? maybe my hearing would re adjust or something ?
4 15's is hella louder than anything else you put in there. your just used to those. if i were you id throw that shit back in there!!!!!!!!!!!!! :)
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
i cant believe ur only hitting 146 with 4-15s?...... What kind of power were u giving them?
Once again im a queerbait fucktard whos banned
the box was never build for spl , its a pure ground pounder .
its tuned to like 30hz -
shit reading is due too
1 cheap box
2 Huge flex in box
3 tuning
4 cheap woofers around $90 - svc
1 cheap box
2 Huge flex in box
3 tuning
well problem 1,2 and 3 can be eliminated by building another enclosure that's stronger, wont flex and tuned to your pleasure.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
