Try another sub and see what happen. If that don't work then the amp might have some issues.
i dont have a sub, but i have a 6x9.. lol but i dont wanna blow it. im tryna sell it
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
Posted (edited)
i made sure, i checked connections at the terminals, and the amp outputs.. their both intact.. and its reading 1.7 ohms, which is what it read 6 months ago when i put them in.
Never mind, beat me to it
Edited by kl0wn
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
Posted (edited)
i cant remember if the 1200 has a output master/input slave switch on it but check that, theyre kinda easy to switch over, and if it did switch over it will turn the output of the amp to the subs off. Its happened to me before on my 2200.
Edited by LunatikGixxer
2002 Dodge durango 4.7L
Autopage 2 way remote start alarm system
2 AQ 15 Aluminum coils.
1 AQ2200D (soon to be 2).
8.5 cubes tuned to 38hz.
Yellow top under hood.
Kinetik 1800 in rear.
Big 3.
(H/O Alt Soon to come)
Kicker ZX200.4
Kicker 6.5 doors (blown)
RF 6.5 comp set (soon to come)
1 run of Stinger 1/0 guage (soon to be 3)
All of the above is all gone
Currently own a 2000 Pontiac Trans Am WS6
No audio components.
thats whut i think it is too. if everything seems to be fine from the outside check the speaker wire on the sub.
Also does ur amp move around while ur driving or is the amp fixed to a certain poistion? Or does anything hit it where the RCAs or Power/ground/speaker wire go in (on the sides)?
amp is mounted down, nothing hits rcas grounds anything, their all strapped down in place as well so they dont move.
Team Sundown Audio
Put the HU and everything on your normal listening volume, and use a DMM to check the output voltage. If there is none, the output's gone.
Also, do the same to the RCA's just to double check.
15.4" widescreen
128MB shared video memory
Windows 7 Home Premium 64 bit
What it does:
On a USB 2.0 Wireless card
check the master/slave switch like lunatik said
i've accidentally done the same thing on mine. should be on master
disconnect the power wire from your amp or pull the master fuse and let it sit for a min. thhen put it back in and see if that works for you.
"i'd rather die like a man than live like a coward" quoted from Tupac
well i connected the 6x9, it worked.. shit,, subs wont play so they gotta be blown.. or something.. now i cant test with my DMM cuz i accidently left it on ohms when checking output voltage, and it aint working for shit now.. so i pulled the subs, smelled them.. no bad smell or anything, they smell like a sub.. cones on both subs move fine, all tinsels appear to be connected...
but if the subs are blown.. i dont see how they could have.. box is built to their specs.. SSF is set to 25-30hz.. so they couldnt have bottomed out i wouldnt think.. they never recieved clipped power.. i bought them in march BNIB on ebay.. better hope that place has a warranty i guess..
Team Sundown Audio
Ooops. Sorry that happened. I know another way to test output but you have to be VERY CAREFUL!
I won't tell you unless you want me too. But do so at your own risk!
15.4" widescreen
What it does:
