so tonight i was on my way home, listenin to music, and at night time i dont really "bump" just drive while listening to music casually.. HU was on about 21 out of 35, so not too loud.. still quiet enough to hear some road noise and i noticed my subs stopped bumpin, so im like wtf ok.. so i turn it up to bout 28 and no bass, at all.. so i turn my head quick.. amp light is still on, green so not in protect.. so i pull into a gas station, check everything.. push on the subs.. they move back and fourth so not seized up.. ground is 100% tight, intact to chassis.. havnt tampered with anything latly.. so couldnt have been anything ive done. the amp was reading an input voltage of 14.2.. so i wanted to see if my clipping indicator could catch clipping (to see if the amp is getting a signal) so i turn vol all the way up, knob on max and it was reading a clipping light... so the amp was clipping, yet no power was being sent out
any suggestions? subs shouldnt have blown, their not even being fed their rated power, between 100-150 RMS less than their rated for, i dont clip the subs/amp... this happened randomly out of the blue, and worked perfectly earlier
any ideas?
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
Start simple, check all your connections, fuses, etc. Normally it's something small if it doesn't smell
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
yeah, no smell.. but main fuse is fine (my highs amp still works) all the fuses in the amp on the sub amp are not blown, rca's are sending a signal.. i hooked the rcas to my highs amp to check and they worked
Team Sundown Audio
or an output problem in the amp. if there was i dont know if the clipping light would still detect anything if that was the case tho. guess it depends where in the circuitry it's integrated into.
well its an AQ1200D
Team Sundown Audio
Are you sure your speaker wire didn't come lose from the sub?
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
i made sure, i checked connections at the terminals, and the amp outputs.. their both intact.. and its reading 1.7 ohms, which is what it read 6 months ago when i put them in.
Team Sundown Audio
Try another sub and see what happen. If that don't work then the amp might have some issues.
thats whut i think it is too. if everything seems to be fine from the outside check the speaker wire on the sub.
Also does ur amp move around while ur driving or is the amp fixed to a certain poistion? Or does anything hit it where the RCAs or Power/ground/speaker wire go in (on the sides)?
Edited by LunatikGixxer
2002 Dodge durango 4.7L
Autopage 2 way remote start alarm system
2 AQ 15 Aluminum coils.
1 AQ2200D (soon to be 2).
8.5 cubes tuned to 38hz.
Yellow top under hood.
Kinetik 1800 in rear.
Big 3.
(H/O Alt Soon to come)
Kicker ZX200.4
Kicker 6.5 doors (blown)
RF 6.5 comp set (soon to come)
1 run of Stinger 1/0 guage (soon to be 3)
All of the above is all gone
Currently own a 2000 Pontiac Trans Am WS6
No audio components.
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
