so i bought a sae1200d from a guy on caco... and i opened it up and i see black spots on the metal pieces on the sides.. and the black comes off on my finger if i touch it... also there are a couple places on the board that looks to me like there has been repairs made.... is there just an obvious way to tell if it has been repaired?
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
im not even sure that its been repaired... but i can tell that it has been really hot.... i still havent tested it... i dont really have anything to power with it at the moment... but it kinda pisses me off... i just dropped $190 on it.... man i hope paypal will work with me if it is fucked up...
3 Kinetik Hc2000's
Dual 200amp alts.
Pics? It'll help a lot.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
really high def pics... you could probably check the solder points and see if any of them look different
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
ill get some pics up... they will be shitty but it should give you a decent idea of what im talking about..
3 Kinetik Hc2000's
Dual 200amp alts.
i mean yea its either been run pretty hot for a while or repaired. but if it works to its full potential than there shouldent be a prob
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
ok uploading pics now... im not even sure if its been repaired... none of the components on the board are broken... but i can see a couple places where it looks like the epoxy has been grinded back from one of the little components.... and there is a spot where the epoxy is melted a little and black...
im going to test the amp after bit... but i have my doubts if it will work or not... ive seen boards with less burns that didnt work....
3 Kinetik Hc2000's
Dual 200amp alts.
