Where to run power wire thru 1990 Cadillac Deville?
trying to run 1/0... cant seem to find a single place it will fit thru without taking the entire dash off, then a lift to get the wire from the bottom... yikes
anyone wired an amp in this car...?
you could always just run the wire under the car and put a protective loom or sleeve over it, ive never done a cadillac but i have done a few chevy's cant think of it being much different, if i remember correctly we had to drill a hole towards the bottom of the fire wall
wich side is the battery on? if its the drivers u can always slide it thru where the hood cable goes...thats where i usually run mine thru. if its in the passanger side you can always drill the hole, just make sure its not too small to cut the wire when u run it thru, and that there isnt anything in the way when you drill the hole. hoep this helps!
well i dont want to run it under the car really... this is just temporary
and i cant fit 1/0g thru the drivers side door jam area
any other ideas
In mine and my moms 92 devilles The shop drilled through the fire wall On the Passenger Side and ran it behind the dash! In my 96 im going to have to drill though the fire wall for my 0g runs B.c there really isnt any holes I can run it though!!! Your only options might be to drill though the firewall or run them under the car!
Team Xtreme Amperage
Xtreme Audio Innovations
XtremeAudioInnovations.com
Facebook.com/xtremeaudio321
4 linked c notched bagged
Fiberglass door panels (5 speakers per door)
dirll a hole and put a gromment it the only thing i can think of
off topic beatbox u need 2 make that pic in ur sig smaller
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
Carefull when u run in the door jam area, my dumb friend did that and his shit caught fire lol You can also do it like steve, check out his honda build. thats clean ass hell, never though of doing it that way....
Passenger side floorboard has a place right behind the power steering line for you to make a solid cut.. I did a 4x4inch square.. and ran all the wires through there..
Before hand I had it running across the top of the car... through the hole on the drivers side for the accelerator... I was able to cut about 5ft off of each run wiring it this way though.
Decent 24TPI jigsaw blade and a simple drill pilot hole. and it'll be worth it. Each run was around 12 foot to the rear.
This was on a 94 Deville though.
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
  • Who's Online   0 Members, 0 Anonymous, 427 Guests (See full list)
