lukedagook Posted December 2, 2009 Report Posted December 2, 2009 i have two dc level 4 xl's but i dont kno how much power i should put to it, or a good amp to use. any suggestions?
Boon Posted December 2, 2009 Report Posted December 2, 2009 A bazillion watts. 35 Stetsom 14kd's parallel strapped, per coil. But seriously. What's your budget, your aims, how big is the box, what size are the subs, daily or SPL, are you very experienced with big power, sealed or ported or crazy quasi-8th order tapered t-line bandpass rear folded horn? What coils are the subs? What is the vehicle? Do you have an upgraded charging system? 10.x volts fo' life!
Marlo Stanfield Posted December 2, 2009 Report Posted December 2, 2009 A bazillion watts. 35 Stetsom 14kd's parallel strapped, per coil.But seriously. What's your budget, your aims, how big is the box, what size are the subs, daily or SPL, are you very experienced with big power, sealed or ported or crazy quasi-8th order tapered t-line bandpass rear folded horn? What coils are the subs? What is the vehicle? Do you have an upgraded charging system? ^^^ All of this we need answered first... I can't see how people expect us to suggest products when we know absolutely nothing about what they are trying to do or currently have. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
loganberry Posted December 2, 2009 Report Posted December 2, 2009 i got a couple amps that would be great for those subs awaiting to see your budget My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
