Guest DC Power Rob
My car iz a 99 Maxima it comes stock with a 100 amp alternator I thought 160 was an upgrade my how I was wrong
Where'd you buy the 160 From? The stock 110 will do almost 160??
He said til he gets his money up.
Keyword !!!! "Start" meaning first bruh. sorry i didnt put a comma in there for u to understand :clapping:
153.3 @ Turkey Drag 2009
Spl Modified 1001-2000 - Derrick Jones my alias... Wudn't accept DEEz NUTz !!!
Didnt know you could buy equipment with no monies? :clapping:
<u>99 Jimmy SLT 4WD</u>
Systemless.
<u>99 Grand Prix GTP</u>
DC XL 12 on 1.5k tuned lowwwwww.
what voice coil configuration do you have??
R.I.P!
(Nov-29-2009)
92 explorer
current build
Still curious as to why the OP would buy all this equipment and wire @ .5ohm daily with a shit electrical to back it up... Did u really just ignore the fact that you need a pretty big electrical to run that amp @ .5ohm daily?? I've said it so many time that it's absolutely pointless to spend all this money on equipment when u don't have any electrical upgrades to run it properly. Just wire it @ 2ohms for the time being, so we don't see a thread in a few days asking if your amp blew. Plus turn the gains down and keep the volume knob low until you upgrade your electrical system. Also do the big 3 upgrade ASAP, it's a cheap upgrade and can be done in a short amount of time.
Even wired @ 2ohms you'll still be seeing sum voltage drops because you really don't have much to back it up.
Pioneer AVIC-N2
seriously man i lent my buddy one of my PB 3000s and its wired up at 4 ohms and with 3 batts she still dims a little on full tilt
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 7042 Guests (See full list)
