8th Wave T-Line DD 3512
IH8PunkRok
drew that up today. its all drawn to scale. 1mm = 2 inches
specs
outside dim
33" W x 17.5" L x 14" H
port is 100 sq inches
8" W x 12.5" H x 53" L
8th wave "tuned" to 32 hz
it isnt much larger than my current box and could be very feasible to do. question is... is it worth it? how good are 8th waves? how will the DD handle it? Foreverbumpn i hope you see this
oh and what kind of power should i put on it? i know it should be half rms but i mean... it is a DD after all...
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
dont forget the 1/4 wave of the box will out do the 1/8th wave, so poly fill should be used
but as long as you have a cabin gain close to the 1/8th wave you may be alright
so 64 will try and be the main tone?
what will the polyfill do?
and im not sure about cabin gain
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
the poly fill will lower the gain of the 1/4 wave, and increase the gain of the 1/8th wave
the pollyfill helps trick the box and make it think its bigger right?
R.I.P!
(Nov-29-2009)
92 explorer
current build
i see. cant say i ever messed with that.
hrm.
im concerned with how much output itll have and how much itll play. right now i have some bad drop offs around 30 and 55 hz in my current box. anything in the 20's is almost gone and anything above 60 is being taken care of by the speakers... sucky
plus i do not have a lot of time or money to invest into something im not sure will work right. but hye thats half the fun isnt it? haha
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
and in tlines it slows down the sound wave, so it seems like a longer line too.
Dang it. I thought i was gonna be the first one to put an 8th wave tline in a car on here.
you still will be no worries. im kinda slow on things like this. i take a lot of time researching and just as long building
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
  • Who's Online   0 Members, 1 Anonymous, 6257 Guests (See full list)
