Forevrbumpn Posted December 3, 2009 Report Posted December 3, 2009 interesting. wheres forever when you need him?why does my little sub sound like ass in an 8th wave? well lemme rephrase that, sounds like ass in comparison to the quarter wave. what speaker are you talking about? Tline's are only really picky with the common SD x's quarter wave technique If the subs Qts is to high, more than likely you have to taper the line, or do a folded horn 1/4 wave will be more powerful than the 8th wave, and a half wave would be more powerful than a 1/4 wave Thats what I heard anyways, to do a half wave box would have gains over the 1/4 wave, and a full wave box will be peaked out, but I never messed with anything over a 1/4 wave I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
IH8PunkRok Posted December 3, 2009 Author Report Posted December 3, 2009 its the little tang band 5.25 on parts express. im really tempted to try a full wave. its kinda expensive tho.. that and i have no room -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Forevrbumpn Posted December 3, 2009 Report Posted December 3, 2009 if you try a full wave, let me know how it works.. haha maybe that sub just ist suited for a tline I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
IH8PunkRok Posted December 3, 2009 Author Report Posted December 3, 2009 if you try a full wave, let me know how it works.. hahamaybe that sub just ist suited for a tline i might try a half wave first. id need 25 feet of pipe for a full wave... jesus -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Boon Posted December 4, 2009 Report Posted December 4, 2009 i might try a half wave first.id need 25 feet of pipe for a full wave... jesus They don't really work in my experience. We built one for an 8 with a crazy labyrinth port and the port velocity was like... nil... by the time it got to the end of the port. Just too much loss, too much air for that little motor to try and move. If you were moving an ass-ton of air and had considerably more Sd than line area (at least at the throat) then you could do it, I think. 10.x volts fo' life!
Forevrbumpn Posted December 4, 2009 Report Posted December 4, 2009 They don't really work in my experience. We built one for an 8 with a crazy labyrinth port and the port velocity was like... nil... by the time it got to the end of the port. Just too much loss, too much air for that little motor to try and move.If you were moving an ass-ton of air and had considerably more Sd than line area (at least at the throat) then you could do it, I think. Your right about that What would work I bet say working on a 60hz full wave This is what I would try and do: 4- 10"s, high fs, but a lot of cone movement start the line internals off at 10"x10" and the line beginning, and end at SD x's 4 say 60sq inch per sub x's 4 240sq inches x's 18+ feet So it would be a horn shape, but if you think of it, that should be the most effective way to do it That should get velocity up good, or do a 5th woofer in the far back, maybe choke the very beginning to a 10"x10"x10" cavity with 5- 10s firing in to it, and 1-10" cut out to get a high velocity escape route but again, that is 18+ feet for 60hz lol but should also peak at 30hz, 15hz as well I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
IH8PunkRok Posted December 4, 2009 Author Report Posted December 4, 2009 i see.. t-lines seem to be becoming increasingly picky with what drivers to use. if i have time im going to try the 1/2 wave this weekend. i have left over pipe from the 1/4 so ill just grab some fittings at lowes -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
