do you know for a fact your getting power back there? good ground and all?
did you upgrade the big three?
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
Im running what you see in my sig ya big 3 and all. Ya im getting power back there cuz my re-q still comes on Im heading out to my other storage house to dig up another amp to test it. If it works my amp is fucked;however if it doesnt work then I have another problem....
if you have a digital multimeter on hand you can just test voltage.
if your getting +12 outta the remote wire and the power wires then your good to go.. and youll know the problem is in your amp.
how did you wire up your subs? maybe theres a load protect where it wont fire up if it sees a certain load under 1 ohm
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
if anything, I would think it would have hurt the main power caps, since they are polarized
That was my first thought however I would think there would be a sign of something burned the amp does not even smell what so ever.
lol I knew someone was going to ask this one and I had them wired to 2 ohms
thats what suprises me at least i was expectin to see popped caps.
im thinkin your gettin no power back there there shoulda been some activity
did you try firing it up with the woofers disconnected
Edited by chewie
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
Man I dunno what is going on Im super confused which is why I posted this I cant believe nothing is burnt up I will try out this hifonics 2600 in the morning to see if im getting power if not then Im going to strip everything out. If so I guess I have to call audioque. If you think or anyone else thinks of anything post it Ima head to bed I have finals at 7 but I'll check out what everyone thinks when I get up... Thanks by the way to everyone
KINDA WIERD!! MINE DIDNT WANT TO WORK UNTILL I HOOKED MY SUBS UP??? NEVER HAD THAT HAPPEN. BUT IT WAS THE SAME ON BOTH MY AMPS. BOTH AQ 2200 BNIB. I FIGURED IT WAS BECAUSE THE ENTIRE POWER LOOP WAS NOT CONNECTED??? BUT THE BOTH SLAM LIKE CRAZY NOW.
THEN AGAIN I DIDNT HOOK EM UP BACKWORDS. ALSO ON THE ISSUE YOUR HAVING A AMP THAT HAS HAD A CURRENT SUPPLIED TO THE CAPS IN THE AMP THEY HOLD A CHARGE UNTIL THE DAY YOU HOOK THEM UP. SO THE FIRST TIME YOU HIT THE KEY TO POWER IT UP AND IT WAS REVERSE CURRENT SO FRY'D IT. IT WONT DAMAGE THE BOARD LIKE SMOKIN IT BUT IT WILL FUCK UP THE MAIN CAPS AND SHIT AND THEY WILL HAVE TO REPLACE IT. REPEAT "NO VISABLE DAMAGE!!! " SEND HER BACK .
[color="#000000"]150's db. in my Beamer!
2 FI BTL 10's FULL TILT!!! Thanks, Scott you've made it all possible! WORLDS FINALS!!!!
1 T 4000.1bd ! Thanks, Forest! R.F. For Life!!
1 DC ALT 350 amps full tilt! thanks, Rob
1 MLA "Syzko Power" Module Thanks Chris you the man!!
2 Kenetic 2400 Battery Beasts!! THANKS ERIC
] MIKE MARTINEZ[/b][/color]
REDID the set up
2 new Fi ??? Full Tilt!!!!! Scotts got me hella hooked!!!
2 audioque 2200's .7 ohm each sub!
1 MLA "Syzko Power" Module Thanks Chris you the man!! 15.8vlts all day!!!
  • Who's Online   0 Members, 0 Anonymous, 1861 Guests (See full list)
