with todays high power systems an iso can actually harm you. it would be continually swithching back and forth and also cause extra wear on the alt. where you might use one.....lets pretend you dont have any amps just a deck and spks. wire in the isolator for main battery and auxilary batery. you go camping shut off the vehical and fall asleep drunk while fishing with the radio on(first youve made sure to be in acc not ignition position on the key) now you wake up and are able to start the truck because your starting battery was not drained. do this too many times and alternator dies because as soon as it starts it switches back to aux and spikes because it has to try to charge a dead battery. not good
http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build"
(1) DC AUDIO Level4XL 10
(2) PowermasterD2700 batteries
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
I have two 1000.1's and im about to get a 350.4 so im guessing getting a 300amp fuse?
maybe possibly a 250 if you wanted too
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
I use a relay between my front battery and my back battery. It has the pros of an isolator but not the cons. It basically disconnections the link between the battery when the car is off or not in accessory, depending on what power supply line the relay is connected to. I have it on the accessories line so I can listen with the car off too if I wanted too.
SPL-Lab REPCar: 1996 Honda Accord F22B1 CoupeSuspension: Megan Racing Full Street Coilover Dampener KitAlternator: DC Power XP 270Batteries: XS Power D5100 & D3100Wiring: KnuKonceptz & 2/0 Welding cableHeadunit: Kenwood KDC-MP642UComponents: Hybrid Audio ClarusAmplifers: Lanzar OPTI250X4Subwoofer: 2 Sundown Audio E8.v2Deadener: Sound Deadener ShowdownSPL Meter: SPL-Lab RTA Pro meterWant an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has the same features? PM me.CA ref: (enellz, 92c1v1c, el_chupo_, Thixx, Kraudio12, SethPhillips, NJack2AF, JamesKarr, ExpoSport, 01 S 10, wgsj_fortvalley, fast306stang, Lakota, blackga, TheLow, adrian1185, the727kid, rudy, sundownz, lmllopez, traksta15, gentlejax, satchel50207, Bigthangs, Goindef154)CACO ref: (extremechevyman67, ghostmechanic, FatBoy2, TheMan007, bdufner, 350zkid, ironb, bmansbach)SSA ref as phi: ( shizzzon, porkchop, onebadmonte, stevemead, TRP, ///M5, denim)SMD ref: (DC Power Rob, Nathan@XSPOWER, Jman08)And then some.
The fuses near the batteries are for the wire and not for the amps. The fuses near the amps are for the amp unless amp's fuses are already on the amp. This is kind of basic.
If the amp has fuses on it you still need to fuse your power wire going into the amp in most applications
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
Thats for the wire and not for the amp. If the amp has fusing on it already, why are you going to protect the fuses that protect the amp? And what applications are you talking about?
  • Who's Online   1 Member, 1 Anonymous, 567 Guests (See full list)
