Ok so ive NEVER had a problem starting my car until the cold hit, it will turn over and then for a split second it will sound like it is going to to start then it just goes back to cranking over.
I tried putting more gas, some HEET, New battery, spraying starter fluid in the carb...no results
I will take any ideas....
2000 chevy blazer
Avic n1
what kind of vehicle we talkin here? is it the bmw in your sig? if its a bmw i cant help. btw i loled at the is there antifreeze in the coolant comment. uh there better be lol.
anyways could be a bad coil, can be checked at autozone, dunno if it has a distributer module could be that if it does, autozone can check that. could be a bad roter in the distributer. ect ect
Edited by yoda132
99 suburban
20" boss motorsport wheels
big 3 installed (thanks Iraggi)
alpine 9886 deck
kenwood 11 band eq
fosgate t5002 amp running sub
kenwood ps200 amp running components
jl xr components in front doors
jl xr 6.5 in rear doors
jl in rear roof
1 FI Q 18" with bp
enclosure 8 cubes 138 sq" port 34hz
Iraggi 220 ho alt
(RF 1500bd coming soon)
Was it a new battery? Are you getting any spark from the spark plug?
Edited by 03silvergt
2017 Chevrolet Silverado LT CC - Will be running 2-3 DC Audion M3 8s, unsure of amp, Mechman 320 amp alt.
2005 Ford F150 - Bagged on 24s, fully shaved, raised bed floor.
sounds like timing
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
are you sure that you have antifreeze in your coolent? that can also cause your car not to start
Yes i just put new antifreeze in a month and half ago
yea brand new battery, and i was going to check the plugs but by time i was gonna it was to dark.
Ill check plugs/distributor/wires tomowwor
2000 chevy blazer
Avic n1
not sure if you tried this already or not, but after putting in the new battery, did you put a charger on it or have another vehicle jump start it? usually the new batteries sitting on the shelf don't work right away without a little extra juice. (at least not for me or my friends.) the battery doesn't seem like you problem, but could be something that simple, so try it if you haven't yet
Pioneer AVH P5900DVD
JL Audio XR525 CSi Components (Kickpanels)
Infinity Reference 6020cs Components (Doors)
JL Audio 12W7 Subwoofer
JL Audio e1800D Amplifier
JL Audio e4300D Amplifier
yea i have tried that, car is hook up on jumper cables is im attempting to start it 90% of the time
2000 chevy blazer
Avic n1
