thanks for the input so far. i will most likely get the fi ssd 10 and make my own box. then when i have enough change ill upgrade with 0 gauge, ho alternator additional battery and a bigger amp (probly sundown). how similar is the se10 from the ssd10? from what ive read it seems that the ssd is much more capable and is easier/cheaper to recone?
SE SERIES
Product Dimension
10"
Mounting Depth - 5.25"
Mounting Hole Diameter - 9.25"
Overall Diameter - 10.25"
Bolt Hole Circle - 9.625"
Motor Width - 6.25"
Motor Depth - 2.5"
Basket Depth - 2.75"
Displacement - 0.12 cu. ft.
Weight - 14.5 lbs.
SE SERIES
T/S Parameters
10"
Electrical Q Value -Qes: 0.39
Mechanical Q Value -Qms: 5.5
Total Speaker Q Value -Qts: 0.36
Free Air Resonance -Fs: 25.3 Hz
Equivalent Compliance -Vas: 31 liters
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency -SPL 1W/1m: 85.3 dB SPL
Effective Piston Area -Sd: 310 cm^2
DC Resistance -Re: 1.8 ohm
Nominal Impedance -Znom: Dual 2/4 ohm
Thermal Power Handling -Pe: 300 W
Force Factor -Bl: 14.35
SSD10
DUAL 1 | DUAL 2
Fs: 28.3 Hz | 27.6 Hz
Re: 0.75 Ohms/coil | 1.5 Ohms/coil
Qms: 4.17 | 4.27
Qes: .48 | .44
Qts: .43 | .40
Mms: 166g | 175g
Cms: 0.19mm/N | 0.19mm/N
Sd: 310cm^2 | 310cm^2
Vas: 25.6 l | 25.6 l
Spl: 82.7dB 1W/1m | 82.7dB 1W/1m
Bl: 9.3 N/A | 14.1 N/A
Xmax: 21mm
Rms: 800W
Sealed box: .2-.6 cuft
Ported box: .9-1.5 cuft @ 33Hz
Sub OD: 11.000”
Cut ID: 9.250”
Mounting depth: 6.000”
Displacement: 0.12cuft
They are different for sure, but I wouldn't throw down on essentially the same sub. It would be better to get something that would handle 1500 RMS like a BL- If you're willing to sacrifice that much cab space.
SE SERIES
Product Dimension
10"
Motor Width - 6.25"
Motor Depth - 2.5"
Weight - 14.5 lbs.
SE SERIES
T/S Parameters
10"
SSD10
DUAL 1 | DUAL 2
Qms: 4.17 | 4.27
Qes: .48 | .44
Qts: .43 | .40
Mms: 166g | 175g
Xmax: 21mm
Rms: 800W
Sub OD: 11.000”
Cut ID: 9.250”
ya im 6'2" so i really dont want to sacrafice any more room than i already have
Whoa.... You got plenty of room bro! Build a box all the way across the back wall, more airspace than you got and make an amp rack either under the seats or floating above the box. You can get a D1 OR D2 Q or BL and throw 1,000- 1,500 watts (1,000 = Q, 1,500 = BL) If you go with D1, you can grab a Maxsonics Maxlink and strap two memphis 500s to the Q @ 1 ohm. You'd be probably just a tad over 1,000 watts and sounding good.
BL10
DUAL 1 | DUAL 2
Fs: 37.1 Hz | 37.1 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 4.62 | 4.62
Qes: .23 | .23
Qts: .22 | .22
Mms: 191g | 191g
Cms: 0.96mm/N | 0.96mm/N
Vas: 13.0 l | 13.0 l
Spl: 86.2dB 1W/1m | 86.2dB 1W/1m
Bl: 16.6 N/A | 22.7 N/A
Xmax: 18mm | 18mm
Rms: 1000W * | 1000W *
Sealed box: N/A cuft | N/A cuft
Ported box: .7-1.5cuft | .7-1.5cuft
Sub OD: 11.000” | 11.000”
Cut ID: 9.250” | 9.250”
Mounting depth: 6.250” | 6.250”
Displacement: 0.16cuft | 0.16cuft
You seem to have space for, at least, 2 10" subs in a ported box! or one 12" ported, without any problem !
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
BL10
DUAL 1 | DUAL 2
Qms: 4.62 | 4.62
Qes: .23 | .23
Qts: .22 | .22
Mms: 191g | 191g
Xmax: 18mm | 18mm
true that. ill take some measurements today and see what i have to work with. i'd like to keep the same shape as the box i have now but place the sub in the center (forward) and port up. so i can lean my seat back all the way without the sub slapping the back of the seat frame. when i get all my measurements, if anyone would be kind enough to help with a box design that would be sweet. ( i'd send a money order to compensate for their time of course) would it be okay to have the sub center forward with port up ontop of it? or should i point the port forward or towards the passenger side like it is now?
again thanks for all the help
no matter your situation get rid of that probox...also i like the SE for your application just as ray said you need more power and a better box
You do realize how similar the design of an RE SE and FI (Lower power handling line) is right?
oh yea, I was thinking of a BTL when typing, your right
but either way a new box would be better
like I said, he should build a new box even if he keeps the sub
I know if I ever find out you were messing with my 17yr old daughter, i'm diggin' off in that ass and then your next post will be asking for tips on how to remove my size 12 shoes from your ass.
Open Up The Trunk
Pioneer P6000Ub H.U.
Sundown Saz-1500D
Hifonics ZXi 4410
12" Directed SX12D4 (x2)
12" 1500rms Sub x1
Front - Powerbass 4XL-65-92 Mids
Rear - Cadence 6.5" Mids
Electrical Under Construction
Check Me Out(CarAudio Vids)
Official Feedback Thread
Check Out My Music Page
  • Who's Online   0 Members, 0 Anonymous, 826 Guests (See full list)
