DUBIE Posted December 10, 2009 Report Posted December 10, 2009 so i was looking at youtube vids and saw this 4th order bandpass enclosure on a 10 and it was bumping preety good. so it got to me. i was thinking if a 4th order bandpass enclosure would work on a Dc level 4 XL 15??.. also i was searching in google for 4th order bandpass enclosure and i also saw theres a 6th order?. whats the difference between these to orders?.. if i build this 4th or 6th order bandpass enclosure it will only be for shits and giggles. see how it sounds. maybe if it sounds BOMB ill just keep it.. any help would be apreciated.. thanks!
uhoh_45 Posted December 10, 2009 Report Posted December 10, 2009 4rth order is a sealed box firing into a ported box as for a 6th order its a ported box firing into a ported box as for your 15 xl your going need a bit of room for a 4rth order atleast 6 cubes i had my 4 apxx 15s in 1.4 cubes each so around 5.5 sealed portion to around 22 cubes ported so for every 1.5 cubes i got sealed i used 5.5 cubes ported R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
jp-kustomz Posted December 10, 2009 Report Posted December 10, 2009 i will work if u have the room id do the 4th 95 Delta 88 10 inch fubar(2 MB Quart RWE-352 15" on way soon) 1500.1 crunch kenwood KDC-MP642U Jp Kustomz
jmitch Posted December 10, 2009 Report Posted December 10, 2009 hate to thead jack but what do yall use to calculate? I know a lil about everything so dont call me Mr. Know it All.
DUBIE Posted December 11, 2009 Author Report Posted December 11, 2009 sorry for the late replies.. if its gona require 6 cubes then thats too much.. i dont think i could fit that in a trunk on a intrepid 96.. how much cubes would i need for a dc level 2 15?..in a 4th order bandpass
siucsaluki11 Posted December 11, 2009 Report Posted December 11, 2009 a 15 in a bandpass needs alot of space, it will still be alot, If you are limited on space, you need to rethink your plan. Go with a smaller woofer if you wanna run a bandpass box. Otherwise go with a good ol ported box. woman..cant live with em...cant shoot em...guess were all fucked You might be a Redneck if you use your leftover gutters for a speaker box port... YOU JUST LOST THE GAMER.I.P. Blazer=========================Last setup was in the 141s on music (37hz) with 2 12s and 1kw in a 4dr blazer.2010 Mitsubishi Lancer DE2 12in Clarions (kept from blazer)HiFonics BRZ1700.1d (at 2 ohms BLOWN) [JBL GTS180X for subs currently 60wRMS x2ch!!!!!! This works for till i get the blown amp fixed] Alpine 4ch salvaged from blazer (currently near death)9887 peerless 7s in the doors and CDT tweeters ran active no speakers in the rearKintik HC1400 under the hood.metered once a while ago, dont remember it...was piss poor compared to the blazer, mid 130s i think....looking to replace subs and amp when i have money.
Boon Posted December 11, 2009 Report Posted December 11, 2009 sorry for the late replies..if its gona require 6 cubes then thats too much.. i dont think i could fit that in a trunk on a intrepid 96.. how much cubes would i need for a dc level 2 15?..in a 4th order bandpass A 15 is a 15... they will probably require really similar airspace. 10.x volts fo' life!
sound xtreme Posted December 11, 2009 Report Posted December 11, 2009 you can make it fit just fine, PM me for more info 1997 Astro front:6 sets of T3 componets Subs: 8 level 5 18"s (building 6th order BP) Amps: 4 really big ones (totalling just shy of 50K) Batts: Alt: Ohio Generator 1996 Chevy Suburban Sub amp: A fifth really big amp Subwoofer: 2-15" DC Level 4 XL Batts: C&D high rate--(x4)
DUBIE Posted December 11, 2009 Author Report Posted December 11, 2009 A 15 is a 15... they will probably require really similar airspace. i guess so huh?.. then ill guess i good ported box for now..
