Team Bass-Hz(JIB) Posted December 12, 2009 Report Share Posted December 12, 2009 Check it out fellas i got this new lap top (im using my deskptop for this) im having trouble with the wireless connection it wont connect and when i try to go in to the settings for it, it takes forever and it doesn't open any ideas on how to fix it Quote Team Bass-Hz Link to comment Share on other sites More sharing options...
pimpedout97x Posted December 12, 2009 Report Share Posted December 12, 2009 what kinda laptop Quote Link to comment Share on other sites More sharing options...
Team Bass-Hz(JIB) Posted December 12, 2009 Author Report Share Posted December 12, 2009 what kinda laptop its a toshiba satellite its started to work after i hooked in the ethernet cable and the wifi on it worked after i unplugged the ethernet cable if there is anything wrong let me please if not i appreciate u tryin to help Quote Team Bass-Hz Link to comment Share on other sites More sharing options...
Doylerules826 Posted December 12, 2009 Report Share Posted December 12, 2009 not sure about windows 7 but this worked on my sisters laptop with windows vista, also a toshiba satellite Start, All Programs\Accessories and right click on Command Prompt, select "Run as Administrator" to open a command prompt. In the command prompt window that opens, type type the following commands: Reset WINSOCK entries to installation defaults: netsh winsock reset catalog Reset IPv4 TCP/IP stack to installation defaults. netsh int ipv4 reset reset.log Reset IPv6 TCP/IP stack to installation defaults. netsh int ipv6 reset reset.log Reboot the machine. Quote 2000 chevy blazer Avic n1 Link to comment Share on other sites More sharing options...
k3n12ock Posted December 12, 2009 Report Share Posted December 12, 2009 Do you have a wireless router? If so, WEP/WAP security on it? You can access your router via it's ip address. They vary depending on your wireless router brand. 192.168.2.2 192.168.2.1 192.168.1.1 192.168.1.2 etc etc or You can press the windows key and R then type "CMD". Next type "ipconfig all" "ipconfig release" "ipconfig renew" Quote 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2 Link to comment Share on other sites More sharing options...
Team Bass-Hz(JIB) Posted December 14, 2009 Author Report Share Posted December 14, 2009 thanks fellas its been working fine after my last post but if its starts to messing up ill surely try those out thanks Quote Team Bass-Hz Link to comment Share on other sites More sharing options...
Ibin Posted December 27, 2009 Report Share Posted December 27, 2009 Do you know what the problem was? Quote Link to comment Share on other sites More sharing options...
Team_DC-Derrick Posted December 27, 2009 Report Share Posted December 27, 2009 my satellite has a little button in the front that a switch, under the keyboard kinda on the left side.. it turns off my wifi connection, you could have 1 and have accidently hit it Quote The DC Integra 3 18s to 6 15 build log Team_DC-Derrick's Youtube Team DC Audio where theres a will theres a wall....... I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones Link to comment Share on other sites More sharing options...
