CaptainzPlanetz Posted December 12, 2009 Report Posted December 12, 2009 This amp looks to be promising, though optimized for 16 volt it will still do near 10K at 14 volts and 12K at 16 volts, from what I have read it was gonna be the Soundstream 12K amp but it never went to production so PP made the amp instead. It has 4 1/0 power imputs and 4 1/0 ground imputs, and 160V rails, so its gonna be putting out some major power. http://www.woofersetc.com/p8384/PDX10K--Pr...t-Amplifier.htm •Class D Topology •RMS Power Output at 2 Ohms: 3,700 Watts •RMS Power Output at 1 Ohms: 6,100 Watts •RMS Power Output at 0.5 Ohms: 10,000 Watts •Power Output 20,000 Watts Max Power •S/N 87 dB at 12kW @ 1 Ohm •All "N" Channel MOSFET TO218 Transistors •Unregulated Power Supply •160 Volt Rails +/- for INSANE Amounts of Power •Capacitance Voltage 200V •Monster SOlid Copper Buss Bars to Pass > 800 Amps of Current •Idle Current Draw 6 Amps •Dual Monoblock Internally Bridged •Maximum Current Draw >1200 amps •Digitally Controlled Module for Damping Factor >1000 @ 100Hz •Short Circuit Speaker Protection •Thermal Protection •Optimized for a 16 Volt DC Power Supply •Totally Separated PWM Circuit to Eliminate Noise •Unique Protection Sensing Circuit for Maximum Power •2.5mm Thick PCB Board (57% thicker than normal 1.6mm) •Over 40 Pounds •Comes with Plexiglass & Metal Bottoms •Remote Bass Control Included •Dimensions: 12 5/8" W x 2 3/4" T x 23 1/4" L •Subsonic Filter 15-50Hz @ 24dB per Octave •Low Pass Crossover 35-250Hz @ 24dB per Octave •Bass Boost 40-120Hz, 0-18dB •(4) 1/0 Gauge Power Input Terminals •(4) 1/0 Gauge Ground Input Terminals •(2) 8 Gauge Remote Turn-On Terminals •(4) 8 Gauge Speaker Output Terminals •The PDX-10K Performs Best with a 16 volt Power Source. Precision Power recommends using a minimum 14.4 volt power source. ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
iTech Posted December 12, 2009 Report Posted December 12, 2009 Nice, I want to try out their component 6.5 sets. I've heard good things for the money for PP. My Official Feedback Thread PSN - tech2332 Games for PS3: Killzone 2, BattleField: Bad Company 2! Add me to play either!
Rose-Villian Posted December 25, 2009 Report Posted December 25, 2009 Ill sell you That PPI 10k For $1800 BNIB WWW.OSGINDUSTRIES.COM I LOVE HATER'S
audiofanaticz Posted December 25, 2009 Report Posted December 25, 2009 Same amp related topic a month ago. http://www.stevemeadedesigns.com/board/ind...precision+power
treossi Posted December 25, 2009 Report Posted December 25, 2009 still pretty cool amp Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
Boon Posted December 26, 2009 Report Posted December 26, 2009 •Dual Monoblock Internally Bridged Weak. 10.x volts fo' life!
