i have 2 15 dual 2 ohm(1500wrms) pushed by a kicker 2500.1
each sub is getting about 1400 wrms!
also getting a .5 ohm stable amp of course!
*if i was to wire them down to .5 ohm would i be able to give them more power?
*^^*also will you give me some examples of amps that run at .5 ohm 3000wrms or higher!
Edited by 03navi
Vehicle: 2003 Lincoln Navigator
Exterior:Custome Air bags, Chrome Grill, 8000K Hid Low & Fogs, 24in rims,Corsa dB Performance Exhaust
Amplifiers:Kicker Kx2500.1, MA Audio M700XE
Batteries: 1 Kinetic Hc2400 Battery
Electrical: STOCK Charging System! Tsunami 40farad Capacitor,
Enclosure: 8 ft³ tuned to 45Hz Interchangeable Ports(34Hz)
Headunit: STOCK! (DVD,CD,Navigation), AudioControl LC6i, AudioControl Epicenter
Mids/Highs: (4)Sets Of Focal Access Component 690 CA1, 2) Sets Of Infinity Reference Tweeter
Subwoofers: 2) 15 Power Acoustik Mofo
Wire: Multiple Runs Of 1/0 Gauge Streetwire Cable
Video: http://www.youtube.com/2treo15
As long as the amp is stable at that ohm load, you have the electrical to back it up, and it's rated higher at .5 ohm than the kicker at 2 ohm. Then yeah it'll be louder.
you culd but i wouldnt try it unless the amp is .5 ohm stable
He said he was going to get a .5 ohm stable amp to replace the kicker with. Or well that is how I am reading the post. Also I use to have a zx300.1 and I ran it at .5 ohm load without any problems except the amp getting rather hot pretty quick.
Edited by kl0wn
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
around how much more power would i be able to give them?
also will i need more voltage to suplly the amp?
ok..
For those beasts in your sig you should snatch up a Sundown 4500.....run that bish @.5!
My POS Bass machine-
2003 Hyundai Santa Fe on some shitty 22's
Bed Liner Paint Job-Pioneer AVH 3200DVD
4 DAD BD series 15's in a 4th Order (Bassheads ENT Design)
4 Arc Audio XDI2000.1 for the woofers
6 Cadence CVL68MBX 6.5's-Cadence CVL88MBX 8's-6 Cadence XT20 Supertweeters
2 Arc Audio KS300.4's for mids and tweets
1 Arc Audio ALD 10v Line Driver
All Audiotechnix Power wire
1 DC Power 270XP High Output Alternator
1 XS Power D3400 up front....6 XS Power D3100's in the rear
Air Lift 1000 Bags in rear to help with suspension
If your still reading this GFY.......
.5ohm is VERY HARD on electrical. electrical wise, what have you upgraded to?
well as of right now,
stock 140 amp alt
kinetik hc2400
duralast 1000 amps in front
big 3 in 1/0
BUT,
im saving to buy a 280 amp iraggi alt
and maybe later on another hc2400!
you mean for thye treo's of mofo's?
Oh....my bad...was looking at the wrong sig info...lol....i was talking about the Treo's
  • Who's Online   1 Member, 0 Anonymous, 1094 Guests (See full list)
