joni13 Posted December 15, 2009 Report Posted December 15, 2009 (edited) Hey guys i was wanting to install a viper 5901 in my 2003 grand prix Gt need some help with all the wiring and what not. if anyone knows a good site or has any advice i would appreciate it Edited January 26, 2010 by joni13 Quote RIP The 03 prix! New Ride 2003 Chevy Tahoe Z71 4 DC LVL 4 18s (2 currently installed) 2 DC PAI.2000 (1 currently installed) 1 DC PAI-120.4
c_stud Posted December 15, 2009 Report Posted December 15, 2009 Hey guys i was wanting to install a viper 5901 in my 2003 grand prix Gt need some help with all the wiring and what not. if anyone knows a good site or has any advice i would appreciate it http://www.modifiedlife.com/2003-pontiac-g...wiring-diagram/ Quote 1998 Nissan 200sx NOW: Dex-p98r head Planet Audio 300.4 mids and highs Planet Audio/Pioneer tweeters/crossovers Skar SK1500.1 3 SKAR Vvx15 dual 4 wired at .63
Shyne151 Posted December 20, 2009 Report Posted December 20, 2009 If you have any questions during the install just post here... Here is the diagram: 2003 Pontiac Grand Prix DirectWire 2.0 Vehicle Information All Products Item Wire Color Polarity Wire Location 12 Volts red + ignition harness Second 12 Volts red/white + ignition harness Starter yellow + ignition harness Second Starter N/A Ignition pink + ignition harness Second Ignition white + ignition harness Third Ignition N/A Accessory orange + ignition harness Second Accessory Third Accessory N/A Keysense Data Bus Can Bus High Can Bus Low Can Bus Sw purple data data link connector under driver dash, pin 2 Power Lock lt. blue - driver kick, door harness Power Unlock white - driver kick, door harness Lock Motor gray 5wi driver kick, door harness Driver Unlock Motor tan 5wi driver kick, door harness Passenger Unlock Motor tan 5wi pass. kick, door harness Parking Lights (-) N/A Parking Lights (+) brown + headlight switch Hazards Turn Signal (Left) Turn Signal (Right) Headlight yellow + headlight switch AutoLights Reverse Light Left Front Door Trigger tan & dk. blue - The tan is located in the driver kick and catches only the driver door. The dk. blue is located in the passenger kick and catches all other doors. Use both wires and diode isolate each. Right Front Door Trigger Left Rear Door Trigger Right Rear Door Trigger Dome Supervision use door trigger Trunk/Hatch Pin red/black - under rear deck Rear Glass Pin Hood Pin N/A Trunk/Hatch Release black/white + release switch On vehicles with keyless entry, can also use brown (-) at the trunk release relay to the left of the steering column. Trunk Release Motor Fuel Door Release Power Sliding Door (Left) N/A Power Sliding Door (Right) Factory Alarm Arm Factory Alarm Disarm orange/black - driver kick, door harness Disarm No Unlock see factory alarm disarm Trunk Alarm Shunt Tachometer white ac pin 8, conn. 2 at PCM The PCM (Powertrain Control Module) is in the air cleaner assembly. Wait to Start N/A Neutral Safety Clutch Pedal Fuel Pump Rear Defroster Mirror Defroster Left Front Heated Seat Right Front Heated Seat Speed Sense dk. green 4K Located at a 10 pin plug on the front of the driver strut tower. There are two dk. green wires there, use the one in the corner of the plug. Brake Wire white + brake pedal switch Parking Brake Horn Trigger black - steering column Wipers gray + steering column Left Front Window (Up/Down) dk. blue - brown A LF window motor in door Right Front Window (Up/Down) lt. blue - tan A driver kick, door harness Left Rear Window (Up/Down) dk. green - purple A driver kick, door harness Right Rear Window (Up/Down) lt. green - purple A driver kick, door harness Quote -Installer for Duke's Car Stereo 2000 Pontiac Grand Prix - Ported Eaton M90 S/C, 3.5" pulley, XS Power Headers, 1.9 Rockers, FWI, Poly Motor Mounts, Custom Tune. RF T1000-1bdCP and T400-4 Boston Acoustics SPG 555 Kenwood eXcelon 995 RF Punch 6.5" components and MB Quart Premium 6x9"s Powermaster Alternator, YellowTop D34, Vmax CT1000
joni13 Posted January 18, 2010 Author Report Posted January 18, 2010 thanks guys i might just leave it to the pro's tho and probably help and try to learn this is somethin i cant mess up Quote RIP The 03 prix! New Ride 2003 Chevy Tahoe Z71 4 DC LVL 4 18s (2 currently installed) 2 DC PAI.2000 (1 currently installed) 1 DC PAI-120.4
