Pics from Thurs. night. In one of the pics is my uncle painting, we are doing the whole car in bed liner. Yes you can do it with a paint brush!
Rear after bed liner
Box w/ bedliner
Stock tails in
All MTX baby
More inside pics, Note the custom speaker cover on the right
BAM here they are
  • 1 month later...
Ok so its been a while since I last posted, we finally got the rest of the stuff. I will be posting pics later tonight now that i'm finally able to use the forum again. I put in 2 12's for mid bass (you can see the box in other pics) the 12's I picked are Thunder Thin 6500's, hooked them up to a 5/ch Jackhammer 500 watts and these lil things rattled the car I was Fu*kin shocked!!! Got the In-dash in and EQ need to finish the dash and the rest of the wiring nightmare then she's done. It has also taken longer than we thought because we used a seperate alt. to run the system well after we got the bracket made and installed we had to modify the front end to make a smaller radiator from newer civic fit in there. FUN, FUN, FUN!
Ok for the whores on here. 3 more pics...........1 quick VID!
The video was shot with my camera, they were hooked up as follows; 8 g. wire from the subs taped to 14 g. wire ran 15ft to my truck to the amp, on stock electrical and a 2 farad cap. Not exactly the ideal setup, but couldn't wait to test it. The test run before this one really flexed that window but when I got the camera out it wasn't so much.
big power + big subs + crx = win
“He has all the virtues I dislike and none of the vices I admire.”
Winston Churchill
Yes I plan on metering it, we built it to have fun in and do comps. It will be a while though no shops here have a meter.
The shitty thing is we looked at one of our parts cars and the a/c bracket would have worked and bolted right up to it.
