i've heard three sundown amps 2 3k and a 3.5k and they all are makin a pop sopund in the woofers, in different vehicle installs, and am not talkn about lower freguencies either am talkin about up in the 41-42hrtz range. so i wouldnt think sub filter. gains not set with an o scope but set very cautious.
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
might be clipping or low voltage or something... i have a saz2k and i have no popping sounds
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
When does this popping sound occur.
On first start up?
When shutting down?
When the volume is move (up or down)?
When tracks change on a song?
How are the electrical (power and ground) set up.
^^^^^^x2 on the low voltage, what is happening there?
I have installed a 3000 and had no isssue and then did a direct swap to a 3500 and it is perfect.
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
Are your decks RCA grounds loose?
Are the amps grounded to one location?
Are the grounds sanded down to bare metal?
Have your tried swapping RCA wires?
Have you checked you voltage with a DMM at the Amp, battery (front/back), also the ohm load?
2003 CHEVY TRAILBLAZER
AKA The Batmobile
Pioneer 6000UB
Sundown SAZ-3000D
2 Audio Q HDC3's
40' of 1/0 Gauge
2 Big Rear Batteries
A 38 HZ Box
KICK ASS!
i was thinkin low voltage was the part of the issue in my boy jeep with the two 3k, but in the other vehicle with the 3.5k the voltage doesnt drop below 12.6 and the poppin begin sumtimes even before the voltages reaches that low. this amp was from db-r so im thinkin that refurb wasnt a good repair. ill try some of you guys ideas and check the other things y'all listed also appreciate all the inputs
Edited by dblovah51
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
Need some more information about when it occurs.
it occurs even before i can set the bass knob to half, gains not even close to half and it does it, voltage no lower than 12.6 at FULL tilt.
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
  • Who's Online   0 Members, 0 Anonymous, 2830 Guests (See full list)
