1371_marine Posted December 19, 2009 Report Posted December 19, 2009 I’m going to be using 5 kinetik HC2400 batts for my system but I don’t know what kind of charging system I need to use to keep them properly charged. I want to use irragi alts but how many and how many amps each is the is what I need to know Anyone that could help i would really appreciate it
Marlo Stanfield Posted December 19, 2009 Report Posted December 19, 2009 Depends on how quickly they will be getting discharged.... What amps are you gonna be running, at what ohm will they be run, and how many?? 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
1371_marine Posted December 19, 2009 Author Report Posted December 19, 2009 Depends on how quickly they will be getting discharged.... What amps are you gonna be running, at what ohm will they be run, and how many?? i will be most likely be using 2 RF T2500.1bd for the subs @1ohm---2 RF T400.2 for the mids @1ohm ---and 2 RF prime R150.2 for the highs unsure of what ohm they will be ran at never had tweeters ran on there own amp im using 2 re audio XXX 18" subs and 2 re audio XXX component set +2 more tweeters
treossi Posted December 19, 2009 Report Posted December 19, 2009 you should check out DC alternators you should give them a call at 1 888 441 0144 they will give you all the information you need Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
dmanson Posted December 19, 2009 Report Posted December 19, 2009 definitely try and run dual alts. your battery bank should be good with what you have named. also you should do at least 3 runs of positive but i'm sure you might know that. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
