audiofanaticz Posted December 20, 2009 Report Share Posted December 20, 2009 thanks but how would i get the wire through the window to begin with? I think ill jsut go this route though so theres no problems Take a pair of needle nose pliers or a vice grip, and just try to pierce it thru the glue seal. Your better off trying to push it out from the inside, then trying to push it in from the outside. But try either way one or the other may work better for you. Quote Link to comment Share on other sites More sharing options...
Bumpindemlowzz Posted December 20, 2009 Author Report Share Posted December 20, 2009 Take a pair of needle nose pliers or a vice grip, and just try to pierce it thru the glue seal. Your better off trying to push it out from the inside, then trying to push it in from the outside. But try either way one or the other may work better for you. thanks mane! Quote 2010 Silverado 18" DC XL 18 DC 2k XS Power Batts Link to comment Share on other sites More sharing options...
audiofanaticz Posted December 20, 2009 Report Share Posted December 20, 2009 forgot to add, heating up the piano wire end when your trying to get thru the seal the first initial time it may help a lot. It will cause the glue to melt around the wire. Kinda like a hot knife thru butter Quote Link to comment Share on other sites More sharing options...
