multi battery question
I installed 2 yellow tops last night and the car already had a cap so I just ran the batteries in parallel with the factory battery and the amp smoked.
heres how its wired
factory battery to cap to amp.
then
factory battery to 1st yellow to 2nd yellow top.
should I have run the amp off the last battery or should I have removed the cap. or both.
I dont like caps but he had it in there because he only had one battery at the time.
PPI dbl din
DC Level 3
1.77cubes net tuned to 33htz.
DC audio 2.0k
you should have done both. it should go factory to 1st yellow top to 2nd yellow top to your amp.
Thanks.
But I do have a question! Why is that so I can have a better understanding????
PPI dbl din
DC Level 3
DC audio 2.0k
i would of personally ran it like this. Factory to 1st yellowtop, Factory to 2nd yellow top, and just pick a batt for the amp
2002 Dodge durango 4.7L
Autopage 2 way remote start alarm system
2 AQ 15 Aluminum coils.
1 AQ2200D (soon to be 2).
8.5 cubes tuned to 38hz.
Yellow top under hood.
Kinetik 1800 in rear.
Big 3.
(H/O Alt Soon to come)
Kicker ZX200.4
Kicker 6.5 doors (blown)
RF 6.5 comp set (soon to come)
1 run of Stinger 1/0 guage (soon to be 3)
All of the above is all gone
Currently own a 2000 Pontiac Trans Am WS6
No audio components.
You ran two separate runs of wire? So one run from factory battery to cap to amp.. An then another set in parallel to the two batteries? Was there a bridge wire between the cap and batteries? What kind of amp was this?
Caps aren't needed much in my opinion when it comes to adding additional batteries. If you are wiring them in parallel with one + and one - for the run to the rear batteries you have done it the correct way. If not you can always ground the battery in the rear of the car though.
What gauge wire and how much power were we trying to pull through though?
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
on top of all the other questions ........... did you have a fuse after the first battery and before the rear batteries?
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Yes
Yes
I think that question was for me. And thinks for answering it wrong, Steven! And not yet. I really want to at a fuse between all batteries but at least he has one on the amp.
I was really aggervated at this install and there is really no room for anything extra.
4^3+ box, 3 bateries in rear, amp bracket and unflexable wire. budget build. and I have used almost all of my own personal wire on several cars. I guess I need to order some wire and start charging for it. I am going to try and convence him to remove the spare tire since you cant get to it anyways and put the batts in there.
PPI dbl din
DC Level 3
DC audio 2.0k
  • Who's Online   0 Members, 0 Anonymous, 1024 Guests (See full list)
