coil burning??
LoudBimmer
i know for a fact that white girl is pretty clipped
what is your Low pass set to?
you should work on your electrical. just a heads up.
back the gains off a little. also let the sub fully cool down before testing again, starting with a hot sub will only make things stink faster. it can take a really hot sub over an hour to cool down
i'm planning on putting new battery in summer. but for now i will probably turn gain down little bit.
let us know if it helps
side note: i don't think a battery would be the best bet for you. if you were dropping into the 10s of 9s i would say yea more battery power
but since you are only dropping to low 12's high 11s, a HO alt would work better in your case and the big 3 wouldn't hurt (idk if you have
already done it or not)
wtf, it's burning again and all i did,is i changed power wire to 1/0 gauge and ground to 4 gauge. before it was 4 gauge for power and 8 gauge for ground.
^problem. fix that ASAP. didnt you have 4awg power and 12awg speaker wire for a ground a while ago? how have you not learned that this is a bad thing yet?
did you turn loudness off? what volume do you turn it up to and whats the decks max? you could be clipping at the HU. as decaf has pointed out many times, it can even be the song has clipped signals in it.
yea its incorrect but its not that big of a deal if hes running 600 rms....That 4 gauge is more than capable....
DAT 4125------>RE XXX comps active
Eclipse cd7000
I serve drunks for a living :D
all the setting are off, my deck was turned up to 20 out of 30 or 40 i'm not sure.
probably just glue though
that's what i'm thinking.
hell no, its a wonderfully loud unclipped song... get the right copy... same with money man... those are top 20 loudest songs i have
shouldn't testing be done correctly? so you'd use 0 gauge
the most amp draw he will have is ~50a... 8g could handle that
the connection of the ground i would look into
put it on auxilary and turn it up with no source so u can find that out
are you positive the sub is wired correctly as well?
check both coils individually if it reads something other than ~2ohms
(i helped you with this box design, right...???)
  • Who's Online   1 Member, 0 Anonymous, 1030 Guests (See full list)
