If your amps are shutting down from getting too hot then they are very worth it.
I have had to use them in about 3 of my personal installs.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
I would think so. Everything runs better when is cool.
1997 Chevy Cheyenne Single Cab
Pioneer DEH-3200UB
Two sets of Orion 6.5" Components In Each Door
AudioQue HDC3 15"
^^^ Its all For Sale!!!!! http://www.stevemeadedesigns.com/board/topic/99546-lots-to-sale-good-prices/ ^^^ AQ2200D
Wow, such a flexy beast(see what i did there lol)
if your amp or amps are goin to be covered up like meads then yeah you might want to consider it but if you have some space around your amp or amps then you don't need them the amps do a good job of cooling themselves if they are overheating check to see if there is something up against the cooling fins or you have an electrical problem
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
Does it help out the subs also from overheating??
LOL if your subs are over heating then you have other issues, like you are trying to push them too hard.
To answer your question it will not help your subs.
or if you are running fullrange Class A/B amps. Class A/B amps run hotter than Class D subwoofer amps and there are still quite a few Class D amps that have fans built in or don't have a fan and still need one.
Plain and simple, if your amps are shutting off and they are very hot to the touch when they shut off then you most likely need a fan on them.
Neither one is overheating i was just curious, I Had a friend ask me about them and it made me wanna know also
