groundpounders inc tahoe build 1 18 lvl 4xl us amps power!
so here is the start of my build it is 1-18 dc level 4XL, going to run on a us amps ax-2000hc. also going to run a us amps ax-tu4360c tube amp on the mids and highs. box is 7.1 after displacements at 31hz, sub up ports back. box will be covered to match the tan carpet in my truck, i just fogged it black till i get around to covering it. still waiting on my 0 ga so i can make my run for the sub amp, and waiting for the tube amp so everything is still a work in progress...
pics.
took my cut sheet to home depot!
more next post!
groundpounders-sig-2.jpg 2002 Tahoe Pioneer 4300dvdFront: Pioneer Components Rear: Kicker CVT6.5 sub amp: US Amps AX2000HC @.35 front stage amp: US Amps TU4360C(tube amps FTW!!)2-18" Level Crossfire XS-SPL V.1'sCheck Out My YouTube Videos!! Click This Now!
this was the amp used in the can cutter videos on youtube!
amp rack, simple, but effective, can't see it in the truck. amp just floats behind the seat, a matching one will be made for the ax tube amp for behind the other seat.
nice bro. i have had better luck with single port boxes tho...
i wanted it this way, the port area is correct as is the length. i went over this with oldschool one night before i finalized the design, he said it should work perfect, and from what i heard tonight...it does.
If oldschool says it will....IT WILL !!!! cant wait to hear it....
153.3 @ Turkey Drag 2009
Spl Modified 1001-2000 - Derrick Jones my alias... Wudn't accept DEEz NUTz !!!
