so I'll temporarily have a 400RMS x 1 @ 2 ohm alpine hooked to my Fi 15" SSD 800RMS how can I get 400RMS from my amp or maxiumum power without clipping or damaging my sub with distortion, would I just turn my gain all the way up and turn any boosts off? I have a DMM would I just hook it up and find 40.0 as in 400RMS?
Current Setup (pictures/videos uploaded)
1997 Grand Prix Se 3.8 V6 (220HP stock)
105A Alternator
Big III
5/8 Gauge Wiring
1 x Alpine MRP-450.1 (1x450RMS @ 2OHM)
1 x Alpine MRP-500.2 (2x250RMS @ 4OHM)
2 x 6 1/2 Infinity Reference 3-WAY (250RMS)
2 x 6 by 9 Infinity Reference 3-WAY (300RMS)
1 x Pioneer dEH-11
1 x 3.5cu .75MDF tuned @ 33hz (VENTED)
2 x Kicker COMP 15" S4
Coming Soon! (pictures/videos included)
1997 Grand Prix SE with rear seat removed
225A Iraggi Alternator
Big III
Rear Deep Cycle
0/1 Gauge Wiring
1 x Alpine MRP-500
1 x Alpine MRP-450
1 x Alpine CDA-9885 60x4 RMS
1 x Hifonics Brutus 1605D (1600RMS x 1 @ 1 OHM)
2 x Fi SSD 15" Copper Coil D1
1 x 5.5cu .75MDF tuned @ 33hz (VENTED)
40v =/= 400w. absolutely not. theres math involved
400w * 2 ohms = 800
the square root of 800 is 28.28
so you need 28.28v (AC VOLTS NOT DC) coming out of the speaker terminals to get 400rms going to the sub. that alpine amp is only stable down to 2 ohms so i hope you dont try to wire it to 1 ohm.
and you have 5 gauge on that amp or something? what do you mean by 5/8 gauge wiring
edit: when tuning the gain turn ALL equalizers off, like bassboost, loud, bass, etc. dont use bassboost on the amp. the only knob or setting you should be changing is the Gain knob on the amplifier. thats it.
when tuning the gains, turn the headunit volume to your general listening level, dont exceed 3/4th volume though. and dont have the sub hooked up either. thats the generally correct way to do it.
400w * 2 ohms = 800
ok thanks, one question why do amps have BASS BOOST nobs and low pass filter etc I should keep those all the way down? my amp is 50-200hz so should I have my amp on 50hz for the best lows? Also I usually listen to my systed at like 28 out of 30 because thats when my speakers and bass is loudest, anything lower than that my speakers arent loud to my liking... anyway to turn my deck upto more than 3/4 volume like say 3.5/4 lol maybe turn gain down just a little to compensate?
Also if its a true 400RMS alpine why can't I just put the gain ALL the way up? doesn that mean 400W is output with full power I guess I'm just confused...
also whats a good testing hz and a good song known for that hz to test with im guessing 50hz since thats what my amp will be set at?
105A Alternator
Big III
5/8 Gauge Wiring
1 x Pioneer dEH-11
Big III
Rear Deep Cycle
0/1 Gauge Wiring
1 x Alpine MRP-500
1 x Alpine MRP-450
because the gain is used hand in hand with the head unit. the higher the output on the RCAs of the head unit, the less the gain has to be turned up. and the lower it is, the higher the gain has to be turned up. so each head unit is different and having the gain turned all the way up would yield different results in each scenario
  • Who's Online   0 Members, 0 Anonymous, 530 Guests (See full list)
