Hey I installed my HIDs this morning from santa and they came on perfect took a ride came back working fine, went out again(they were so pretty) and they were working fine, then I left to go pick up my grandma and I jumped out to look at them again because they are sexy... and my drivers side one is out. So I turn it off and on and I see it flicker then turn off(just the drivers side one goes off). I have a relay on my ballasts and my grounds are good, is one of my ballasts bad?
Edited by BulletInjection
Its a bad ballast on the side of the HID thats bad... I too had a bad ballast when i first installed my H.I.D.'s 2 years ago.. Guess you gota go thru warrenty and all that... Its sucks but it happens..
Also you can use different size ballasts in the H.I.D world..
Edited by Stallion Marauder
2003 Mercury Marauder Black (R.I.P)
Tinted Windows
Purple HID's 10000K
Fog Light HID's 10000K
Swi Jack Steering Wheel Controls
Apple I-Pod Classic 80GB
Alpine KCE-422i Full Speed I-Pod Cable
Alpine IVA-W203/P1 Navigation/Bluetooth
Alpine PKG-M780 7' Headrest Screens
Alpine PXA-H701 Sound Processor
Alpine MRP-F300 4 Channel Amp
Rockford Fosgate 1501bd Power Amp
2 Kicker L7 15' Solo Barics
Alpine Type R SPR-17S Component's
Alpine Type R SPR-57C Coaxial's
Monster Performance RCA's
0/2 Gauge Wires
BIG III W/Fuse
200 Amps Custom Built Alternator
Yellow Cap Optima Battery Front
Xstatic Batcap 800 Back
Custom Mounted Bass Knob
LED's 2x License & Trunk Light
BoYo VTK-350 Color Backup Camera
Dynamat Xtreme Front Doors & Rear Deck
Clifford Matrix 50.7X Alarm System/Remote Start
did you get a RELAY with the HID kit? if you DIDNT sometimes only one of the headlights will turn on or try to turn on "flicker" when you turn your headlights on. i had that problem with mine, i didnt get a realy and i had to wait a week for it. then after that they started right up. hope this helps. GL
Yeah I got a relaybecause of the 6 amps needed to get them started up and stock only puts out 3-4amps and those grounds were sanded down so those are good, I guess ill call them in the morning and send the relay back. im not really even sure of the brand because I did not buy them.
its def. a bad ballast...i had 2 go out on me...when u get ur replacement ballast make sure their mounted really good to keep them from movin around
the only person i wouldnt let build my box would be Ray.
Team Heavy-Flex4 SA 12's tuned to 29hz
Ampere Audio 3800.1 @ 1 ohmXS Power D3100Big 3Stock alt
Also if its not the Ballast then its definitley the Relay.. Relay's are known to go bad too and have the same issue as a bad Ballast going out with one bulb being on, or both not turning on..
Just replace it with another 5 pin Relay..
Tinted Windows
Purple HID's 10000K
0/2 Gauge Wires
BIG III W/Fuse
  • Who's Online   1 Member, 0 Anonymous, 690 Guests (See full list)
