BulletInjection Posted December 25, 2009 Report Share Posted December 25, 2009 (edited) Hey I installed my HIDs this morning from santa and they came on perfect took a ride came back working fine, went out again(they were so pretty) and they were working fine, then I left to go pick up my grandma and I jumped out to look at them again because they are sexy... and my drivers side one is out. So I turn it off and on and I see it flicker then turn off(just the drivers side one goes off). I have a relay on my ballasts and my grounds are good, is one of my ballasts bad? Edited December 25, 2009 by BulletInjection Quote My build: http://www.stevemeadedesigns.com/board/ind...8920&st=100 http://www.youtube.com/Bulletinjection Link to comment Share on other sites More sharing options...
Mosin Posted December 25, 2009 Report Share Posted December 25, 2009 What brand is the HID? Quote Derp. Link to comment Share on other sites More sharing options...
treossi Posted December 25, 2009 Report Share Posted December 25, 2009 yeah id double check the grounds and everything again even though you say they're good.. still want to know what brand Quote Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details Link to comment Share on other sites More sharing options...
Stallion Marauder Posted December 25, 2009 Report Share Posted December 25, 2009 (edited) Hey I installed my HIDs this morning from santa and they came on perfect took a ride came back working fine, went out again(they were so pretty) and they were working fine, then I left to go pick up my grandma and I jumped out to look at them again because they are sexy... and my drivers side one is out. So I turn it off and on and I see it flicker then turn off(just the drivers side one goes off). I have a relay on my ballasts and my grounds are good, is one of my ballasts bad? Its a bad ballast on the side of the HID thats bad... I too had a bad ballast when i first installed my H.I.D.'s 2 years ago.. Guess you gota go thru warrenty and all that... Its sucks but it happens.. Also you can use different size ballasts in the H.I.D world.. Edited December 25, 2009 by Stallion Marauder Quote 2003 Mercury Marauder Black (R.I.P) Tinted Windows Purple HID's 10000K Fog Light HID's 10000K Swi Jack Steering Wheel Controls Apple I-Pod Classic 80GB Alpine KCE-422i Full Speed I-Pod Cable Alpine IVA-W203/P1 Navigation/Bluetooth Alpine PKG-M780 7' Headrest Screens Alpine PXA-H701 Sound Processor Alpine MRP-F300 4 Channel Amp Rockford Fosgate 1501bd Power Amp 2 Kicker L7 15' Solo Barics Alpine Type R SPR-17S Component's Alpine Type R SPR-57C Coaxial's Monster Performance RCA's 0/2 Gauge Wires BIG III W/Fuse 200 Amps Custom Built Alternator Yellow Cap Optima Battery Front Xstatic Batcap 800 Back Custom Mounted Bass Knob LED's 2x License & Trunk Light BoYo VTK-350 Color Backup Camera Dynamat Xtreme Front Doors & Rear Deck Clifford Matrix 50.7X Alarm System/Remote Start Link to comment Share on other sites More sharing options...
BeatBox Posted December 26, 2009 Report Share Posted December 26, 2009 did you get a RELAY with the HID kit? if you DIDNT sometimes only one of the headlights will turn on or try to turn on "flicker" when you turn your headlights on. i had that problem with mine, i didnt get a realy and i had to wait a week for it. then after that they started right up. hope this helps. GL Quote Link to comment Share on other sites More sharing options...
BulletInjection Posted December 26, 2009 Author Report Share Posted December 26, 2009 did you get a RELAY with the HID kit? if you DIDNT sometimes only one of the headlights will turn on or try to turn on "flicker" when you turn your headlights on. i had that problem with mine, i didnt get a realy and i had to wait a week for it. then after that they started right up. hope this helps. GL Yeah I got a relaybecause of the 6 amps needed to get them started up and stock only puts out 3-4amps and those grounds were sanded down so those are good, I guess ill call them in the morning and send the relay back. im not really even sure of the brand because I did not buy them. Quote My build: http://www.stevemeadedesigns.com/board/ind...8920&st=100 http://www.youtube.com/Bulletinjection Link to comment Share on other sites More sharing options...
BeatBox Posted December 26, 2009 Report Share Posted December 26, 2009 damn that sucks man. when my ballast went out they wouldnt even turn on so.....yeah give them a call and hoepfully they can replace it. Quote Link to comment Share on other sites More sharing options...
BulletInjection Posted December 26, 2009 Author Report Share Posted December 26, 2009 Yeah I hope it all gets resolved quickly and pain free so I can throw in my D2700(coming soon) and this little set of upgrades can be done with Quote My build: http://www.stevemeadedesigns.com/board/ind...8920&st=100 http://www.youtube.com/Bulletinjection Link to comment Share on other sites More sharing options...
Sp33dyG Posted December 26, 2009 Report Share Posted December 26, 2009 its def. a bad ballast...i had 2 go out on me...when u get ur replacement ballast make sure their mounted really good to keep them from movin around Quote the only person i wouldnt let build my box would be Ray. Team Heavy-Flex4 SA 12's tuned to 29hz Ampere Audio 3800.1 @ 1 ohmXS Power D3100Big 3Stock alt Link to comment Share on other sites More sharing options...
Stallion Marauder Posted December 26, 2009 Report Share Posted December 26, 2009 (edited) Also if its not the Ballast then its definitley the Relay.. Relay's are known to go bad too and have the same issue as a bad Ballast going out with one bulb being on, or both not turning on.. Just replace it with another 5 pin Relay.. Edited December 26, 2009 by Stallion Marauder Quote 2003 Mercury Marauder Black (R.I.P) Tinted Windows Purple HID's 10000K Fog Light HID's 10000K Swi Jack Steering Wheel Controls Apple I-Pod Classic 80GB Alpine KCE-422i Full Speed I-Pod Cable Alpine IVA-W203/P1 Navigation/Bluetooth Alpine PKG-M780 7' Headrest Screens Alpine PXA-H701 Sound Processor Alpine MRP-F300 4 Channel Amp Rockford Fosgate 1501bd Power Amp 2 Kicker L7 15' Solo Barics Alpine Type R SPR-17S Component's Alpine Type R SPR-57C Coaxial's Monster Performance RCA's 0/2 Gauge Wires BIG III W/Fuse 200 Amps Custom Built Alternator Yellow Cap Optima Battery Front Xstatic Batcap 800 Back Custom Mounted Bass Knob LED's 2x License & Trunk Light BoYo VTK-350 Color Backup Camera Dynamat Xtreme Front Doors & Rear Deck Clifford Matrix 50.7X Alarm System/Remote Start Link to comment Share on other sites More sharing options...
