Ok, so I'm a little dissapointed..
are you trying to run the sub at 2 ohms and will the sub run at 2 ohms? If you're trying to do 400 rms and are cabable of doing it 2 ohms then your gain should be set at 40v on the DMM... square root of 400=20, 20x2=40
You're problem may be the sub amp config. I may have missed what your sub is.
15" Fi SSD with copper coils D1 VC
Alpine MRp-450 @ 2OHM (so yes im running 2 ohm...)
400RMS @ 2 OHM
I have my sub wired up right and everything, I actually played the sub on a 50hz tone @ 40v and it sounded clean as hell I believe.
Just play a 50hz tone, play with the gain and turn it up till it sounds shitty at 3/4 volume than back off till it sounds clean.
EDIT: don't use bass boost either.
Shit my bad...been up all night!
yes its 28.28...double check your wiring too.
http://www.stevemeadedesigns.com/board/ind...hl=setting+gain
doing it my head for the quickness when tired is z..zz.zz.z
I have two speakrs wire soldered together connected the coils positive to negative... I have no oppositve polatiry all positives and negatives are how they should be and all my wiring the amp is fine... I don't know what it could be guys... I bet a lot of people running this subwoofer on 400RMS are doing what I did and set the gain really high with bass boost.. Now I'm not going to do that but I fail to see how anyone could be getting full excursion on 400RMS with the same voltage im running.
Alpine MRP-450... I mean whatever I'll just live with it i'd rather not argue about something so stupid... If you think its my box go ahead and assume, but when I'm telling you its not you shouldnt force it into me lol.
when a bunch of expert box builders are telling you that your box is the problem... you should choose to listen!... especially when one of them designed his own box calculator... anyways... what they are trying to tell you is... the difference in output between getting a new amp and getting the right box... may be similar...
also your only giving that woofer half its rated power... and not to mention that it is very underrated!.. you will not reach full excursion unless you are running a box twice the recomended size..
anyways you pretty well pissed me off when you asked questions and then refused to listen to the advice.... thats pretty sablenave of you....
so... my advice is... stop dicking around with halfassed stuff... honestly you are NOT going to find an amp that puts out 1500rms for under 200 or whatever your price range was... and honestly... you would be lucky to get 1000rms of decent power on that budget.... then ask very nicely for someone to design you the correct enclosure for your woofer... and then build it correctly...
that is all for now
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
that is all for now
I thought they didnt' make 1600RMS in a $200 price range? LOL hifonics does... I honestly don't care what you say I apoligized, these box builders don't even know my dimensions and you're telling me its my box? eh, ok... also my car won't fit twice that size i'd be lucky to fit 6cubes in my car. I don't care if I pissed you off TBH you've done nothing for me but annoy the shit out of me.... How am I half assing btw? Fi and Alpine are bad brands since when? and nty I can design my own box kthx =)
To be honest this thread is pointless...what did you make this to bitch as us about how you cant 400 watts to sound loud?lmao re build your box get real power end thread...
RE se xxx 18d2 (4)
Audioque 2200 (2)
DC Power 270XP blue
3 C&D fr310
Stinger wiring
CDT components
