sorry i couldnt help, looks like u have something working for ya
if u are going to kerf those two parts u should just do all three, no sense in have the port wall be like that
if you move the dowel rod from side to side forward a little bit u wont need the second dowel rod in the port
ideally you dont want anything in the port if u dont have to, ive found doubling the walls on each side provides greater strength than the dowels in the port and it creates less turbulence
Wouldn't kerfing the back port piece change the tuning quite a bit so if have to get the enclosure completely redesigned but I think that would be a great idea
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
Hey dont mean to but in on this one...but i could be wrong....
Dont you with expo's "new" Calc, when using a wall for a side of the port have to use the height as how far from the side it is?
If you swap the height and width of the port the tuning comes out to 38sh hz.
Edited by tristan560
<u>99 Jimmy SLT 4WD</u>
Systemless.
<u>99 Grand Prix GTP</u>
DC XL 12 on 1.5k tuned lowwwwww.
"when doing a slot port...just check the slot port box in the program and it will automatically figure in half of the port height for you into the tuning make sure to use *port height* as the distance from the port wall to the box wall."
Systemless.
driver displacment is .21cuft
bracing is ~.1cuft
so thats .31cuft which changes tuning even more
i would like to know why andym85's box calc and exposports have such different results
with the same box calc ive always used since day one, with the info gotlungz is using i got
[email protected]
should be more like 4.5@34
i dont think thats what u wanted dccavalier
Edited by Decaf
Yeah same here...im sick of getting mixed results and never knowing exactly what my boxes end up truly being. Everything i use i come up with a different result....i was hoping id get you in here decaf. So you use andy's?
Systemless.
absolutely because i can view his math in each cell, so i dont have to question anything like in expo's (no offense)... i simply look to see if his math was correct
basically all andy did was put the "pencil and paper method" in excel so its faster
  • Who's Online   0 Members, 0 Anonymous, 2583 Guests (See full list)
