Hey guys
i just installed windows 7 diamond edition, and got a qeustion.
how do i control my cooler on CPU? i have CoolerMaster Hyper TX2.
btw, here's specs on my PC
CAS:Raidmax Sagitta II Mid-Tower 420W Gaming Case w/ Side-Panel Window (Black Color)
CS_FAN: Extra 3-Color Neon Light LED Case Fan
CPU: AMD Athlon X2 6000+ Dual-Core CPU w/ HyperTransport Technology
CD: Sony 20X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLUE COLOR)
FAN: CoolerMaster Hyper TX2 Gaming CPU Cooling Fan (Extreme Silent Operation at only 22dBA + Overclock Proof)
MOTHERBOARD: Asus M2N SLI NVIDIA nForce 560 SLI MCP Chipset DDR2/800 SATA RAID PCI-Express MBoard w/GbLAN,IEEE1394,USB2.0,&7.1Audio
MEMORY: (Req.DDR2 MainBoard)2GB (2x1GB) PC6400 DDR2/800 Dual Channel Memory (Corsair or Major Brand)
NETWORK: ONBOARD 10/100 NETWORK CARD
POWERSUPPLY: 635 Watts Power Supplies Sigma Shark SP-635W PSU - SLI Ready)
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
USB: Built-in USB 2.0 Ports
VIDEO: NVIDIA GeForce 8500 GT 1GB 16X PCI Express (Major Brand Powered by NVIDIA)
WNC: PCI Wireless 802.11g 54Mbps Network Interface Card
  • 1 month later...
with that CPU: AMD Athlon™ X2 6000+ theres no reason you should have to change the fan speed. those are super cool running chips
01 GMC Sonoma 4x4
RF T1500.1bd
DC LVL 4 12"
make sure first that the bios is set to some sort of user control, and not manually locked in. If your bios has these options. Your question is a little incomplete for me to tell you how, as your not giving me enough info on other neeed specs. however programs like speedfan (that was mentioned) is a nice and small program.
I love my staffie :good:
So anti FACEBOOK it isn't even funny
yea speed fan can control it, MOST of the time ASUS will bundle some software with there boards that will allow you to control it. as newis stated check you bios. if you cannot control the speed in there chances are the option is not available on the board. then you will want to get a fan controler
01 GMC Sonoma 4x4
RF T1500.1bd
DC LVL 4 12"
Also depends on the board and the fan. If it has a 4 pin connector then it's controlled by PWM and just about any fan control program should be able to handle it. Speedfan is good. If it only uses a 3 pin connector then you need a board that supports direct voltage control and not all of them do...
Either way, speedfan.
10.x volts fo' life!
