Mosin Posted January 2, 2010 Report Posted January 2, 2010 Vehicle - 1995 GA GT, Quad-4, 5-Sp. Like the title states what is a clutch interlock switch? What does it do? Can it be bypassed for anything good? Derp.
Namosh Posted January 2, 2010 Report Posted January 2, 2010 I had an old Nissan 4WD pickup that had an interlock button. It lets you turn the starter over without pushing in the clutch. My Ram Quad Cab Blow-through
Mosin Posted January 2, 2010 Author Report Posted January 2, 2010 So if I push it in and hold it I can start my GA without pushing the clutch in? Derp.
Namosh Posted January 2, 2010 Report Posted January 2, 2010 On mine you didn't have to hold it. Just hit it once and it will crank over until you let off the key. My Ram Quad Cab Blow-through
Mosin Posted January 2, 2010 Author Report Posted January 2, 2010 Mine could be the same way. I haven't tried it yet. I found this: If the engine won't run and you're in a precarious position, or it's too dangerous to take your foot off the brake and it's in gear, you can use the starter motor to move you out of that precarious position while you're in gear without having to push the clutch pedal in to get the starter motor to run. Is this the only real benefit of said switch? Derp.
Namosh Posted January 2, 2010 Report Posted January 2, 2010 Or if you happen to run out of gas at a railroad crossing, you can crawl off the tracks with the starter. Other than that, I don't know of any practical use for it. My Ram Quad Cab Blow-through
