so i got my remote start installed today and the guy tapped off the fuel injector so that the remote start would know to quit cranking, well this made my truck run like complete shit to say the least, i unplugged the tap that he had on there and it runs great, so my question to you guys is, what should i tap into besides the injectors and coil packs that would tell the remote start to stop cranking the engine?
vehicle is a 99f150 w/ the 5.4
Edited by abervintageman42
tapping the injector is not a big deal was it the odd wire on the injector though?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Can you check to see the wire he tapped was lt. green/white at the coil on the passenger side of the motor between the fuel injectors ??
That is the true tach wire on the 5.4L motors
Ascendant Audio Hawaii Rep
Sundown Audio Hawaii Rep
what exactly does that mean?
the tach wire should've been tapped to a lt. green with a white stripe wire
when you pulled the tach wire off was the wire it was attached to lt. green with a white stripe
Edited by theabunai
That's not the right wire.. is there a wire next to the one he tapped that is green with a white stripe wire
just to be sure this is a 1999 ford F150 5.4L truck right ?
if it is I am confident that the wire is Green with a white stripe
Edited by theabunai
  • Who's Online   1 Member, 0 Anonymous, 576 Guests (See full list)
