So everything is installed, now I have another problem
Everything I got today (amp, eq, voltmeter) came in today and everything was installed. The humming noise I had before is gone :D The problem now is if I turn the music up, at certain noteds, the sub sounds like it's choking and emits all kinds of funky bass. Anyone have an idea what that would be? Tomorrow I'm going to move the ground to a different place and take the sub out of the box. Any more suggestions?
you eq probibably has a higher output voltage, just turn your gain down a little and it should help
R.I.P!
(Nov-29-2009)
92 explorer
current build
Subsonic is at 30? That sounds a bit high to me
well if his box is tuned to 34-36hz then thats just right anything lower and youll damage the woofer
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
with my amp set perfect, round wave the lows sound like ass
back off on the gain a tiny bit and they come through like normal
try adjusting your gain a little.. :good:
Wouldnt be thehoe92 without teh purple
Box is tuned to 32 (supposedly). I will DMM it tomorrow with the 50hz 0db track I have. See if that makes a difference. I hate adjusting my music in my neighborhood. Scared of thieves.
same deal for a lot of people, its either thieves or pissed off neighbors, try to find an empty parking lot nearby or an isolated area where no one is around
  • Who's Online   0 Members, 0 Anonymous, 906 Guests (See full list)
