I used my laptop all morning and it worked just fine then 4 hours later i get on it and it freezes. I restart it and it says "disk read error". Im guessing its a connection or the harddrive but is there anything i can do before taking it in to repair? its a toshiba satalite A205 i believe.
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
Posted (edited)
Yeah i have disks and it gets past the first loading screen thats preloaded from toshiba then goes blank and says the message.
Edit: Now it says cannot locate harddrive...
Edited by dccavalier
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
Sounds like the hdd has failed.
The Setup
2009 Volkswagen Jetta
2 Alpine SWR-1222D's in 2 seperate boxes tuned to 33hz
1 Kicker ZX1001.1
Stock 140A Alt
Stock speakers
Those LT's suck...my friends sister has one and I had to reinstall Vista from her recovery disk last week
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
its been a good laptop and definately lasted longer then it should have. maybe ill just get a desktop since i wanted one for a while
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
Do some troubleshooting before you jump into buying a new one. If you have a spare laptop pop the hdd into that one and see if it boots, if it does then the hdd is fine and it is something with your laptop. If the hdd passes check your memory.
The Setup
1 Kicker ZX1001.1
Stock 140A Alt
Stock speakers
  • Who's Online   0 Members, 0 Anonymous, 689 Guests (See full list)
