Okay thanks guys! I'll be sure to get plenty of pics this time & a video maybe. I've never done a setup in an SUV before, but I have a feeling this thing is gonna pound pretty good. B)
OOOOOOOOOO Whats this going into!?
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
You still will be able to master/slave those amps together. It seems though that one amp may be more powerful than the other.
I know some of the earlier model T10001bd only put out alittle over 1000w @ 1ohm and the newer models are around 1500w @ 1ohm. My board is red and mine is a refurb of the 2006 model. It didn't come with a birthsheet but I know it's putting out around 1500w rms.
Well, the birthsheet from my older model with the green board says 1518rms @1ohm, but I have no clue about the one I just bought because he didn't have the sheet anymore. He said he thought it was maybe around 1150rms, but that seems kinda low for me, most T1000's are rated at above 1400rms as far as I've heard
2001 Chevy Blazer (Blue)
He's having the alarm installed as I type this. I can't wait to get my hands on this one guys! :D
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
Wrong if you invert a sub you should reverse the polarity on them otherwise you will have two subs firing into a sealed chamber. you need to reverse the polarity so the sub fires in reverse and it still has a sealed back chamber.
Scientia est Vox
SMD SUPER BUYER/SELLER
I've seen a couple of birhtsheets that were that low. I've also seen some that were rated higher a 2ohms than they were at 1ohm. Which amp has the smaller capacitors?
Edited by j_black10
AudioControl
Rockford Fosgate
XSPower
a9cb521a-b3b0-4848-8950-41c45879dd3f_zps
Will it hurt the subs if I wire them normally? I suppose I could try it both ways to see which one sounds better...
The green board amp (older T1000) has smaller caps.
1- T1000.1bd's
4 runs of 1/0 gauge
-Big 3
All in a CAR.
Usually they just sound like ass, unless the surround gets damaged by the box.....
Scientia est Vox
Thanks guys, I really appreciate the advice. I have no experience inverting subs so I was lost of this subject. So all I do is turn - into + for all four coils, & that isn't gonna hurt the subs either?
1- T1000.1bd's
4 runs of 1/0 gauge
-Big 3
All in a CAR.
X2!!!!!
Back in the day I tried it and it sounded horrible. Haven't done it since!!!
Hopefully that amp puts out around 1500w rms!! It sucks if it doesn't!!! But like I said before, it won't affect you being able to master/slave them!!!!!
Edited by j_black10
AudioControl
Rockford Fosgate
XSPower
Okay cool, well I'm about to go manufacture a type of switch box so it's done when he pulls up in about 3 hours. I will catch all of you guys later, & once again thank you for your help!
B)
1- T1000.1bd's
4 runs of 1/0 gauge
-Big 3
All in a CAR.
  • Who's Online   1 Member, 0 Anonymous, 1020 Guests (See full list)
