No, sae line cant run .5, fuses pop and so will the amp most likely. Just wire to 2 ohms and be happy. That will yeild you around 6-700 rms in its self.
formerly known as Blue86f150
this sux camel dicks
^This
That amp is rated at 600W @ 2ohms and I'm sure that is at 12.8V like all the rest of the Sundown amps, so it wouldn't be necessary to run .5 to get 600-700 watts.
HU: Pioneer
Highs: 2X 4X6"s, 2X 3.5"s, 4X 5.25" comps, Q-Logic kicks, and a Sundown SAX-125.2
Subs: 4 Nightshade 15s and Strapped SAZ-3500Ds <---Sundown FTW good.gif
Electrical: dual DC Power 320s (ordered) and 2 D3400s up frt and 4 D2700s in the back
.ʇı ɥʇıʍ ʞɔnɟ ʇ,uɐɔ noʎ 'ʞɔıp ǝɹos ɐ ǝʞı1 sı uʍopunS
no, i just wonna see how this 10" will sound on 600wrms
i ran it before on 300wrms, and it had some good SPL
specs on sub:
YEAR 2001 MODEL AUDIOBAHN AW-1008X 10" SUB 1000W RMS 189 BRAND NEW IN FACTORY SEALED CARTON
10 PRO-PRESSURE SUBWOOFER CHROME PLATED
CAST ALUMINUM BASKET
CHROME BACK PLATE
1000 WATTS R.M.S. POWER HANDLING
1500 WATTS MAX. POWER
200oz of Precision Engineered Multi-stacked Magnets
PHAT 2 FOAM SURROUND
NON- PRESSED, NON-TRANSSFER PAPER CONE
Bolt Tight Motor Structure
Laminated Glass Fiber Composite/Pulp Cone
NICKEL PLATED TERMINALS
3 Inch 4-Layer AVS Voice Coil
Dual 1 Ohm Voice Coils
1/2 Ohm or 2 Ohm Operation
Frequency Response: 20Hz 500Hz
Efficiency: 87dB
Mounting Dimensions: Depth; 6 Inch Hole; 9 1/4 Inch Diameter; 10 7/8 Inch
Edited by nfsplayer
  • Who's Online   0 Members, 0 Anonymous, 1111 Guests (See full list)
