No, sae line cant run .5, fuses pop and so will the amp most likely. Just wire to 2 ohms and be happy. That will yeild you around 6-700 rms in its self.
formerly known as Blue86f150
its a 4th order just because its tuned in the 40z doesnt mean it wont reach down and jiggle your balls at sub 30 hz frequencies.
Regardless if they were dipped platinum and were stuffed in Beyonce's twat.....way too fucking exspensive
this sux camel dicks
^This
That amp is rated at 600W @ 2ohms and I'm sure that is at 12.8V like all the rest of the Sundown amps, so it wouldn't be necessary to run .5 to get 600-700 watts.
HU: Pioneer
Highs: 2X 4X6"s, 2X 3.5"s, 4X 5.25" comps, Q-Logic kicks, and a Sundown SAX-125.2
Subs: 4 Nightshade 15s and Strapped SAZ-3500Ds <---Sundown FTW good.gif
Electrical: dual DC Power 320s (ordered) and 2 D3400s up frt and 4 D2700s in the back
.ʇı ɥʇıʍ ʞɔnɟ ʇ,uɐɔ noʎ 'ʞɔıp ǝɹos ɐ ǝʞı1 sı uʍopunS
no, i just wonna see how this 10" will sound on 600wrms
i ran it before on 300wrms, and it had some good SPL
specs on sub:
YEAR 2001 MODEL AUDIOBAHN AW-1008X 10" SUB 1000W RMS 189 BRAND NEW IN FACTORY SEALED CARTON
10 PRO-PRESSURE SUBWOOFER CHROME PLATED
CAST ALUMINUM BASKET
CHROME BACK PLATE
1000 WATTS R.M.S. POWER HANDLING
1500 WATTS MAX. POWER
200oz of Precision Engineered Multi-stacked Magnets
PHAT 2 FOAM SURROUND
NON- PRESSED, NON-TRANSSFER PAPER CONE
Bolt Tight Motor Structure
Laminated Glass Fiber Composite/Pulp Cone
NICKEL PLATED TERMINALS
3 Inch 4-Layer AVS Voice Coil
Dual 1 Ohm Voice Coils
1/2 Ohm or 2 Ohm Operation
Frequency Response: 20Hz 500Hz
Efficiency: 87dB
Mounting Dimensions: Depth; 6 Inch Hole; 9 1/4 Inch Diameter; 10 7/8 Inch
Edited by nfsplayer
  • Who's Online   0 Members, 0 Anonymous, 1330 Guests (See full list)
