HID Legal Trouble?
hows get gonna have to pay money for LIGHTS? if he gets 4300 or 6k prob even 8k hell be fine, your gonna sit and tell me NEW LEXUS CEDES BENZ get pulled over for having hids in the cars? No they come factory so as long as hes not running blue purple pink yellow hes fine.
Do you know what projectors are? An how they work? An why the newer cars have them?
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
projectors project the light STRAIGHT in front of the vehicle instead of i guess you could say sprawling it from left to right INVENTED FOR HIGH END RACING USE AT NIGHT WHEN DOING 100 MPH+++
Keep going, there's a bit more to it than that.
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
Headlamps using projector optics cause much worse dazzle to oncoming traffic than those using reflectors for the same light output. Dazzle from the headlights of a distant oncoming vehicle is caused by the extreme contrast between the intense spot of light and the darkness of the background. Projector optics emit the light through a much smaller area than reflector optics do; therefore, for the same total light output, the light spot of a projector headlamp is much more intense and more dazzling than the larger, dimmer light spot of a reflector lamp.
It is sometimes argued that the more tightly controlled beam pattern of projector optics reduces dazzle. In fact the beam pattern is irrelevant, since unless the headlamps are misaligned, an oncoming vehicle is sufficiently far off the beam axis as to be completely outside the beam in both reflector and projector cases. The dazzle is caused by the off-axis emission arising from such factors as scattering from optical imperfections in the lamp surface, and is worse where the more concentrated output of projector optics causes that emission to be more intense.
the thing is, they are legal, but only if thAt's how the car came frome the factory
doesnt matter, if the vehicle came with it, your gonna tell me if DMV approves of a open header exhaust on C concept car your mass produced A car cant use it?
Read more, pull more random articles off of google and paste it here for us to learn something from.
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
im done i tried proving my point TEK stay away from abnormal colors your 4300 6k and 8k should be fine
