you could also add another variable just to read in that null character.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
perfect
thanks Brian
did you move that line to the other location? If not, it will error if you type in anything other than m the first time. It needs to be inside that do loop so it kills the new line each time enter is pressed.
Once you get more advanced, there are ways to get rid of that new line character. There are functions that do it for you, or you store the variables as stings instead of characters. You read the string until you see the new line. At that point, the new line is gone and the input is wating for the next character.
C++ is much better for input and output.
Brian
Edited by bkolfo4
Current system:
Previous systems:
Used this when i was 15, and stopped there. only did a calculater, miclock, and this muilty crap that opens the trays..
if its a basic program... go to youtube or google, most likly they'll be a tutorial. thats how i learned
Brian that second thing you told me to do with scanf does not work
the prgram opens for a second and then closes. does not wait for input
i fucked something up
thanks for the help tho man
Edited by IH8PunkRok
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Put it back in the original position I told you to put it in (above the do loop) and then see what happens if you type in the wrong letter.
Brian
Current system:
Previous systems:
