just a helpful hint if you can find any of this stuff its called Kroil, it works a thousand times better than PB Blaster, it goes into spaces small as a millionth of an inch and a small propane torch on it and spray some KROIL on it and it should turn out as easy as a pie
1997 4 Runner
Alpine CDA-9886
4 Fi Audio X Series 12's
1 Crunch GP3000D Pro
DC Power Inc. Alternator(Kickin out 15+ volts!)
kinda off top/ i haven't used any of the penetrating stuff but the engine cleaner i've used and it cleaned a bunch of gunk out more than the average cleaner did
1998 Nissan 200sx
NOW:
Dex-p98r head
Planet Audio 300.4 mids and highs
Planet Audio/Pioneer tweeters/crossovers
Skar SK1500.1
3 SKAR Vvx15 dual 4 wired at .63
yep... godda use pb blaster and let her sit overnight and then try to get a small pipe wrench in there...
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
Vice grips can be your friend!
+1000000000 bazillion!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
03 GMC Sierra Z71 Ext Cab l 2 15" American Bass XO's l 1 Lanzar HTG2600 l AudioVox 1510D In dash DVD l KnuKonceptz Wiring l Big Three Done with KnuKonceptz KLMX 1/0 l Infinity Reference 6022si 6-1/2" Front Door Speakers l Upgraded to 145A Alt from 105A Alt l Custom Box 2^3 under the rear bench with resined bottom, and about 4 lbs of polyfill
